What hz level is this?
DannyD
For all of you own the transformers dvd or bluray, there's a seen in the movie just after bumble bee hands Sam the all spark during the fighting scene downtown, I think its star scream that comes flying down and shoots a missle right at the start of the slowmotion action and there is a long deep swooping bass part in the movie. I'm curious to know just how low my subs are getting at this point in the movie and if I'm hearing distorted bass because it's too low for my subs to handle(they are supposed to go flat to 23HZ) or if it's clean low bass that I can smile about?:D
Fronts: RTI10's
Center: CSIA6
Rears: RTIA3's
Sub: 15" Velodyne DLS5000R x2 Stacked:D:D:D
Amp: Marantz MM-9000 150wpc (bi-amped for RTI10's) and CSIA6
Blu-Ray: PS3
Harman Kardon AVR247
Monster Cables
Signal Analog II IC's
Panamax MP-5300 Power Conditioner
Center: CSIA6
Rears: RTIA3's
Blu-Ray: PS3
Monster Cables
Post edited by DannyD on
I believe the Ironhide flip is somewhere in the mid 30s. Your subs should handle it fine unless there's a suckout in your room.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Are you talking bad accoustics like peaks and nulls? Also do you or anyone know of specific movie scenes that get your subs into the 20-25hz range?Fronts: RTI10's
Center: CSIA6
Rears: RTIA3's
Blu-Ray: PS3
Monster Cables
Panamax MP-5300 Power Conditioner -
I was actually worried about this the first time i saw it.... sounded a little weird on my dual S8s, so i swapped them out for the Klipsch, which automatically ramps back when it encounters distortion, and i had to get up to some serious volume before it started to level off.
I think it's just a strange sound.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
Thats kind of why I'm asking...I'm trying to distinguish the difference between distorted bass and clean bass. I think it's alot easy to hear on smaller speakers other than your subs.Fronts: RTI10's
Center: CSIA6
Rears: RTIA3's
Blu-Ray: PS3
Monster Cables
Take a look at the sub during that part of the movie. Is it moving unnaturally.....move in different positions when listening to the sub to see if you can hear distortion (above it, side of it, in front, back 3 feet, etc). When you are in parts of the room where it's boomy, it's going to be harder to hear distortion.Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors** -
There's a ton of energy below 25hz in the WOTW pod emergence scene. There's also a ton above, so you might not notice what you're missing. The Haunting DTS has a scene called Creaking Pipes...huge door banging centered at 22hz that will peal wallpaper...it's very easy to hear a sub driven beyond it's limits for this one. Pulse, an awful movie, has a computer room scene with a continuous 18hz tone, that's very hard for most subs to handle cleanly. LOTR, the ring drop sweep gets down to 22hz, sounds like the Ironhide flip, but lower. 23hz is your 3db point, but your sub will go lower, just not with a great deal of output. It will be distorted, but you might not notice as it's close to infrasonic due to lower output and audibility.
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Does having two subs increase their ability to handle lower bass than what a single one would be able to handle?Fronts: RTI10's
Center: CSIA6
Rears: RTIA3's
Blu-Ray: PS3
Monster Cables
Not really. Still the same rolloff, but you will get 3-6dbs more output. Meaning there is some subsonic stuff that becomes audible, but the higher frequencies still mask it. However, running 2 subs really takes the load off. Each is working half as hard with less distortion (if calibrated flat or close to it with the mains). The extra headroom means a considerable uptick in linearity and sound quality.Does having two subs increase their ability to handle lower bass than what a single one would be able to handle?
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Not really sure the actual hz of the clip, but the famous "Darla" scene in Finding Nemo digs pretty darn deep.bms
Family Room:
Onkyo TX-RZ920
Outlaw 2200 monoblock amps x 3
Sony UBP-X700
Sony A80J 77” OLED
Polk LSiM 705’s
Polk LSiM 706
Polk LSiM 703’s
Polk RTi4's
Dual SVS PB13-Ultra’s
PC13-Ultra
Bonus Room:
Onkyo TX-SR806
PS3
Panasonic TC-P42G10
Polk RTi10's
Polk CSi5
Polk R50's
SVS PB10-ISD
For sale:
Onkyo TX-SR603X -
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
7.1 SURROUNDS: RTI6'S
XBOX 360WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
http://polkarmy.com/forums/index.phpbobman1235 wrote:I have no facts to back that up, but I never let facts get in the way of my arguments. -
Thanks BIZILL! This is perfect:DFronts: RTI10's
Center: CSIA6
Rears: RTIA3's
Blu-Ray: PS3
Monster Cables
This is very nice - thanks Bizill!bms
Family Room:
Onkyo TX-RZ920
Sony UBP-X700
Sony A80J 77” OLED
Polk LSiM 705’s
Polk LSiM 706
Polk LSiM 703’s
Polk RTi4's
PC13-Ultra
Bonus Room:
Onkyo TX-SR806
PS3
Panasonic TC-P42G10
Polk RTi10's
Polk CSi5
Polk R50's
SVS PB10-ISD
For sale:
Onkyo TX-SR603X -
yeah, someone posted this site back when i was in search of the same as you fellers. quite handy-dandy indeed. i burned a disc with all tracks. cool to use in for my system in my truck too.
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
Ron Temple wrote: »There's a ton of energy below 25hz in the WOTW pod emergence scene. There's also a ton above, so you might not notice what you're missing.
WOTW broke the cone on my Dayton 15 TitanicIII:eek: Scared the crap out of me!Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I won't take that one beyond reference. I've still got some gas in the tank at 115dbs, but I'm scared to try Ben levels of volume. Probably couldn't get there anyway :eek:.WOTW broke the cone on my Dayton 15 TitanicIII:eek: Scared the crap out of me!
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
What movie is WOTW
Never mind it just came to me War of the worlds
So you guys know, use those sine wave tones sparingly - just long enough to get a reading with a SPL meter. Sine waves, especially below 30Hz, can heat up the voice coil on a sub with a quickness. You can overheat the voice coil if you're not careful.Equipment list:
Onkyo TX-NR3010 9.2 AVR
Emotiva XPA-3 amp
Oppo BDP-93 Blu-ray player
Epson 8500UB 1080p projector
Elite Screens Sable 120" CineWhite screen -
Thanks for that warning-Good to know.____________________
Pool: Atrium 60's/45's -
I'd only watch out near the port frequency. If it's tuned to 30 Hz, don't blast a 30 Hz sine wave, because that's the frequency of least cone motion.
Sealed boxes can take any frequency just fine.
