What hz level is this?
DannyD
DannyD Posts: 133
For all of you own the transformers dvd or bluray, there's a seen in the movie just after bumble bee hands Sam the all spark during the fighting scene downtown, I think its star scream that comes flying down and shoots a missle right at the start of the slowmotion action and there is a long deep swooping bass part in the movie. I'm curious to know just how low my subs are getting at this point in the movie and if I'm hearing distorted bass because it's too low for my subs to handle(they are supposed to go flat to 23HZ) or if it's clean low bass that I can smile about?:D
Fronts: RTI10's
Center: CSIA6
Rears: RTIA3's
Sub: 15" Velodyne DLS5000R x2 Stacked:D:D:D
Amp: Marantz MM-9000 150wpc (bi-amped for RTI10's) and CSIA6
Blu-Ray: PS3
Harman Kardon AVR247
Monster Cables
Signal Analog II IC's
Panamax MP-5300 Power Conditioner
  • Ron Temple
    Ron Temple Posts: 3,212
    edited September 2008
    I believe the Ironhide flip is somewhere in the mid 30s. Your subs should handle it fine unless there's a suckout in your room.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • DannyD
    DannyD Posts: 133
    Are you talking bad accoustics like peaks and nulls? Also do you or anyone know of specific movie scenes that get your subs into the 20-25hz range?
    Fronts: RTI10's
    Center: CSIA6
    Rears: RTIA3's
    Blu-Ray: PS3
    Monster Cables
  • concealer404
    concealer404 Posts: 7,440
    I was actually worried about this the first time i saw it.... sounded a little weird on my dual S8s, so i swapped them out for the Klipsch, which automatically ramps back when it encounters distortion, and i had to get up to some serious volume before it started to level off.
    I think it's just a strange sound.
  • DannyD
    DannyD Posts: 133
    Thats kind of why I'm asking...I'm trying to distinguish the difference between distorted bass and clean bass. I think it's alot easy to hear on smaller speakers other than your subs.
    Fronts: RTI10's
    Center: CSIA6
    Rears: RTIA3's
    Blu-Ray: PS3
    Monster Cables
  • curved
    curved Posts: 664
    Take a look at the sub during that part of the movie. Is it moving unnaturally.....move in different positions when listening to the sub to see if you can hear distortion (above it, side of it, in front, back 3 feet, etc). When you are in parts of the room where it's boomy, it's going to be harder to hear distortion.
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
  • Ron Temple
    There's a ton of energy below 25hz in the WOTW pod emergence scene. There's also a ton above, so you might not notice what you're missing. The Haunting DTS has a scene called Creaking Pipes...huge door banging centered at 22hz that will peal wallpaper...it's very easy to hear a sub driven beyond it's limits for this one. Pulse, an awful movie, has a computer room scene with a continuous 18hz tone, that's very hard for most subs to handle cleanly. LOTR, the ring drop sweep gets down to 22hz, sounds like the Ironhide flip, but lower. 23hz is your 3db point, but your sub will go lower, just not with a great deal of output. It will be distorted, but you might not notice as it's close to infrasonic due to lower output and audibility.
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • DannyD
    DannyD Posts: 133
    Does having two subs increase their ability to handle lower bass than what a single one would be able to handle?
    Fronts: RTI10's
    Center: CSIA6
    Rears: RTIA3's
    Blu-Ray: PS3
    Monster Cables
  • Ron Temple
    DannyD wrote: »
    Not really. Still the same rolloff, but you will get 3-6dbs more output. Meaning there is some subsonic stuff that becomes audible, but the higher frequencies still mask it. However, running 2 subs really takes the load off. Each is working half as hard with less distortion (if calibrated flat or close to it with the mains). The extra headroom means a considerable uptick in linearity and sound quality.
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • bms
    bms Posts: 182
    DannyD wrote: »
    Not really sure the actual hz of the clip, but the famous "Darla" scene in Finding Nemo digs pretty darn deep.
    bms
    Family Room:
    Onkyo TX-RZ920
    Outlaw 2200 monoblock amps x 3
    Sony UBP-X700
    Sony A80J 77” OLED
    Polk LSiM 705’s
    Polk LSiM 706
    Polk LSiM 703’s
    Polk RTi4's
    Dual SVS PB13-Ultra’s
    PC13-Ultra
    Bonus Room:
    Onkyo TX-SR806
    PS3
    Panasonic TC-P42G10
    Polk RTi10's
    Polk CSi5
    Polk R50's
    SVS PB10-ISD
    For sale:
    Onkyo TX-SR603X
  • BIZILL
    BIZILL Posts: 5,432
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • DannyD
    DannyD Posts: 133
    BIZILL wrote: »
    Thanks BIZILL! This is perfect:D
    Fronts: RTI10's
    Center: CSIA6
    Rears: RTIA3's
    Blu-Ray: PS3
    Monster Cables
  • bms
    bms Posts: 182
    BIZILL wrote: »
    This is very nice - thanks Bizill!
    bms
    Family Room:
    Onkyo TX-RZ920
    Sony UBP-X700
    Sony A80J 77” OLED
    Polk LSiM 705’s
    Polk LSiM 706
    Polk LSiM 703’s
    Polk RTi4's
    PC13-Ultra
    Bonus Room:
    Onkyo TX-SR806
    PS3
    Panasonic TC-P42G10
    Polk RTi10's
    Polk CSi5
    Polk R50's
    SVS PB10-ISD
    For sale:
    Onkyo TX-SR603X
  • BIZILL
    BIZILL Posts: 5,432
    yeah, someone posted this site back when i was in search of the same as you fellers. quite handy-dandy indeed. i burned a disc with all tracks. cool to use in for my system in my truck too.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    XBOX 360
  • ben62670
    ben62670 Posts: 15,969
    Ron Temple wrote: »
    WOTW broke the cone on my Dayton 15 TitanicIII:eek: Scared the crap out of me!
    Ben
  • Ron Temple
    ben62670 wrote: »
    I won't take that one beyond reference. I've still got some gas in the tank at 115dbs, but I'm scared to try Ben levels of volume. Probably couldn't get there anyway :eek:.
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • kweb
    kweb Posts: 25
    edited October 2008
    What movie is WOTW
  • kweb
    kweb Posts: 25
    edited October 2008
    Never mind it just came to me War of the worlds
  • kuntasensei
    kuntasensei Posts: 3,263
    edited October 2008
    So you guys know, use those sine wave tones sparingly - just long enough to get a reading with a SPL meter. Sine waves, especially below 30Hz, can heat up the voice coil on a sub with a quickness. You can overheat the voice coil if you're not careful.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • mmadden28
    mmadden28 Posts: 4,283
    edited October 2008
    Thanks for that warning-Good to know.
    ____________________
    Pool: Atrium 60's/45's
  • ShinAce
    ShinAce Posts: 1,194
    edited October 2008
    I'd only watch out near the port frequency. If it's tuned to 30 Hz, don't blast a 30 Hz sine wave, because that's the frequency of least cone motion.
    Sealed boxes can take any frequency just fine.
