Sunfire help.
paymontna
TGP 5.....TG 7....Sony upconvert DVD...No sound. I get white noise from the speakers when I unplug the amp, so I know they are getting juice. The only other source I have available at the time is my Ipod. The Ipod should just plug into any of the jacks with male to male right. I am not getting any sound. I bought the TGP new and I tested everything before I put the system away before I sold all of my speakers. Any one?
Chris
Chris
And I mean calling all cars, blackhawk down, mushroom cloud, Three Mile Island, lock the door behind you kind of mad.:mad:
Post edited by paymontna on
go into the menu and check all the settings.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Yep; menu is the first place I'd look. Did you buy them new or used? What source are you plugging into? Got pics of the back of your setup?TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
Stupidity moment. Amongst a rabid, new speaker haze, I was trying to use the 8.1 speaker outputs
. Cost me a couple of hours of trying to figure out what was wrong. I got it all worked out now, and am ready to hook up my new system.
PayAnd I mean calling all cars, blackhawk down, mushroom cloud, Three Mile Island, lock the door behind you kind of mad.:mad:
