Sunfire help.
paymontna
paymontna Posts: 188
edited October 2008 in Electronics
TGP 5.....TG 7....Sony upconvert DVD...No sound. I get white noise from the speakers when I unplug the amp, so I know they are getting juice. The only other source I have available at the time is my Ipod. The Ipod should just plug into any of the jacks with male to male right. I am not getting any sound. I bought the TGP new and I tested everything before I put the system away before I sold all of my speakers. Any one?
Chris
And I mean calling all cars, blackhawk down, mushroom cloud, Three Mile Island, lock the door behind you kind of mad.:mad:
Post edited by paymontna on
  • cfrizz
    cfrizz Posts: 13,415
    edited October 2008
    go into the menu and check all the settings.
  • TNRabbit
    TNRabbit Posts: 2,168
    edited October 2008
    Yep; menu is the first place I'd look. Did you buy them new or used? What source are you plugging into? Got pics of the back of your setup?
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • paymontna
    edited October 2008
    Stupidity moment. Amongst a rabid, new speaker haze, I was trying to use the 8.1 speaker outputs :D. Cost me a couple of hours of trying to figure out what was wrong. I got it all worked out now, and am ready to hook up my new system.
    Pay
