Does anyone else do this?
$mitty
$mitty Posts: 33
My receiver isn't capable of adjusting the crossover for individual speakers (front/rear). It adjusts all of them at once.
Does anyone else set their bass output to "both" (front and sub) rather than setting it to just "sub"? I like the extra bass I get from my front speakers, and it also allows me to adjust the crossover for my rear speakers, which are smaller. Otherwise, the crossover is either too high or low to work well with my front and rear speakers when set to "sub" b/c they can't be adjusted individually.
My AVR sends LFE to only the sub, but sends bass to both the sub and the front speakers. Do you think it could be putting too much strain on my front speakers by using them this way? Their lower limit is 50Hz.
Mains - TSi200
Center - CS10
Surround - TSi100
Sub - PSW110
AVR - Yamaha RX-V663
Movies/Games - PS3
Music - iPod Nano
Satellite - DirecTV HD
TV - Panasonic 46PZ85U
PSN - mrSM1TTY
Post edited by $mitty on
  • $mitty
    $mitty Posts: 33
    edited October 2008
    Nevermind...I'm changed rear speakers and the problem should be solved! Instead of OWM3s, going with the TSi100s. I'll play around with it and get this thing tweaked right.
    Mains - TSi200
    Center - CS10
    Surround - TSi100
    Sub - PSW110
    Movies/Games - PS3
    Music - iPod Nano
    PSN - mrSM1TTY
