Should I add another subwoofer?
Polkie918
Polkie918 Posts: 245
edited October 2008 in Speakers
I have a 10" velodyne sub that puts out some real good bass....
my dad has a sony 12" powered sub just laying around not being used.....should I hook it up
or with them being different sizes and such ....it wouldnt sound right? or be too much bass?
what do u think thanks
Fronts- RTi8
Center- CSi5
Rears- FXiA4
Sub- Velodyne 12"
Onkyo TX-SR806
Ps3
Xbox 360
65" DLP 1080P Toshiba TV
Post edited by Polkie918 on
  • DannyD
    DannyD Posts: 133
    edited October 2008
    You can never have too much bass!:D
    Fronts: RTI10's
    Center: CSIA6
    Rears: RTIA3's
    Sub: 15" Velodyne DLS5000R x2 Stacked:D:D:D
    Amp: Marantz MM-9000 150wpc (bi-amped for RTI10's) and CSIA6
    Blu-Ray: PS3
    Harman Kardon AVR247
    Monster Cables
    Signal Analog II IC's
    Panamax MP-5300 Power Conditioner
  • McLoki
    McLoki Posts: 5,231
    edited October 2008
    hook them up one at a time, and adjust them both to the same volume level.
    then hook them both up and adjust the volume level in the AVR.
    yes, I think it will be worth your time to hook them both up.
    Michael
  • NewHTguy
    NewHTguy Posts: 584
    edited October 2008
    I have a similar question as I just bought a new sub (Velo SPL1200R) and still have my old one (JBL Sub12) sitting around. Thought about trying both but do not know how to do it. My Onk 875 has only one LFE. Can I use both? Would I use the L/R channels?
    MAIN: Polk Lsi9s; Polk PSW505; Lsic (in box); Onkyo SR-875; Parasound 2250; Cambridge Audio 740C; LG BD370
    OFFICE: Polk Lsi7; REL T3; HK 3490; CA 840W; Onkyo C-S5VL
    BENCHED: CS20; OWM3s
  • McLoki
    McLoki Posts: 5,231
    edited October 2008
    Get a Y splitter. (one male to 2 female) you will also need an additional subwoofer cable - but you should be good to go.
    The only time I would not consider running an additional sub is if one FAR outclasses the other. (I did not run my polk PSW-350 with my SVS. All it could do is make the bass worse)
    treitz3 Posts: 19,951
    edited October 2008
    It is not advised to run two different subs on the same system. Cancellations are your worst enemy among other things.......
  • kuntasensei
    kuntasensei Posts: 3,263
    edited October 2008
    treitz3, that's why you locate the subs in the same spot. Co-location is your friend with dual subs. Or if you had a pair of identical subs, you could run them stereo off the mains... but that's a whole other discussion.
    That said, that Sony is handily outclassed by the Velodyne... so the original poster might just be making it sound worse. Sony subwoofers are usually pretty muddy sounding.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • danger boy
    danger boy Posts: 15,722
    edited October 2008
    Polkie918 wrote: »
    i think you have enough subwoofers.. go and listen to them now. if you don't like what you hear. buy some more. :p
    PolkFest 2012, who's going>?
  • Monster Jam
    Monster Jam Posts: 919
    edited October 2008
    NewHTguy wrote: »
    Wow - thats the exact two subs I have. I use the JBL for casual music, and the Velodyne for serious HT duty.
    Do you hear that buzzing noise? :confused:
  • NewHTguy
    NewHTguy Posts: 584
    edited October 2008
    Monster,
    Haven't been using the JBL because the Velo is so awesome. I was looking for a musical sub and think I made a good choice going with the Velo. Do you have them on the same system? Are you using a Y cable like what was suggested to me above?
  • Monster Jam
    edited October 2008
    No, they are in different rooms. The JBL isn't a great sub by any stretch, but I didn't buy it to be a great sub - I bought it to fill in some low end for casual listening.
    I haven't ever attempted running them together with a Y - it would be tight in my space-constrained HT room.
