Niles controllers
jerryjerry1963
I am hooking up my sound system and have run into a problem. I have 2 LC80I speakers I am hooking up on zone 2 of an Onkyo 805 receiver. I built a new house and Niles volume controllers were used (by the builders audio guy)for the zone 2 areas i want to install speakers into. After installing the speakers and wiring to my receiver, I tried it out only to be very disappointed in the sound quality. Sounded like a bad FM static reception (not horrible but noticeable). You can imagine my disappointment after researching and putting quite a bit of money into my system. I tried several things to diagnose the problem and finally bypassed the Niles in wall controller. The sound quality improved quite a bit. This is good, however, I need the wall controllers in my house. are the Niles a low quality controller? I did try switching out with another in wall controller in the house with the same result. Is there something I am missing here?
Post edited by jerryjerry1963 on
What were the the settings on the volume control set at? 1x,2x,4x etc. How many speakers do you have hooked up? Are you using a speaker selector box?
