Bedini Ultra Clarifier
dc55110
Anyone have any experience with the Bedini Ultra Clarifier (dual or quadri beam)? I recently had a chance encounter with one at local hi-fi shop. Now I will preface my next statement by letting you know what I heard was through one of their reference systems (Wadia 581i Se CDP > Ayre KX-R pre > Ayre MX-R mono's > Wilson Maxx series 3). With that said... The sound difference between a cd played without the Bedini treatment and the same played after was not only noticeable but undeniably better - much more clarity, increased volume, wider soundstage!
At less the $200 new for the dual beam I think it might be one of the greatest sound improvements for the buck.
But I'm cheap, so now to track down a used one.
(((STEREO)))
Sony DVP-N9000es
Squeezebox Duet
Theta ProBasic IIIA
Audio Research SP14
White Audio Labs B1
Transparent SoundWave Super
Paradigm Studio Monitor
B&W 802 s3
HT
Sony Bravia KDL-40Z4100
Sony BDP-S350
Yamaha HTR-5790
NHT SB3 (Fronts)
NHT SC2 (center)
NHT SB2 (surround)
Velodyne FSR12
Sony DVP-N9000es
Squeezebox Duet
Theta ProBasic IIIA
Audio Research SP14
White Audio Labs B1
B&W 802 s3
HT
Sony BDP-S350
Yamaha HTR-5790
NHT SB3 (Fronts)
NHT SC2 (center)
NHT SB2 (surround)
Velodyne FSR12
Post edited by dc55110 on
You should be able to acieve the same effect with one of these, they go for about $19.95.
http://www.dvguru.com/2006/10/03/the-dvd-rewinder/ -
That's what I thought when I was told what it Bedini was supposed to do. Then I heard it. And then I tried it again. And again. Then with another system at the store, same result. Call it snake oil now, try it, then tell me what you think.(((STEREO)))
Sony DVP-N9000es
Squeezebox Duet
Theta ProBasic IIIA
Audio Research SP14
White Audio Labs B1
B&W 802 s3
HT
Sony BDP-S350
Yamaha HTR-5790
NHT SB3 (Fronts)
NHT SC2 (center)
NHT SB2 (surround)
Velodyne FSR12 -
I was seriously trying to offer a cheaper solution, I forgot to mention that you must glue two magnets to the bottom of the DVD rewinder.
If you are willing to spend the money, the Bedini is great, but it's not complete on it's own. Here's what you do, make sure you do it in the order listed, that's critical for the best results.
Start with the Bedini, but don't run it once, run it twice. After treating with the Bedini twice, go to step two, which is the Auric Illuminator CD treatment:
http://www.positive-feedback.com/Issue16/auric.htm
Use just the drops, as the pen is not very effective, it's the wrong color. Use the CD Stoplight instead, much better results:
http://www.elusivedisc.com/prodinfo.asp?number=AP-CDSL
Your almost done now, so onto the final step:
http://www.6moons.com/audioreviews/machinadynamica2/ib.html
Presto, your done!
If you thought the Bedini was good, wait until you try the full treatment. You will not only think the band is right in your living room, you will actually feel the performers sitting on your lap! It's amazing. -
Dammit-somebody always steals my ideas. That's the last time I bring one up at the bar. :mad:
I was about to mention the Machina Dynamica product. Brilliant stuff. Take a look at some other goodies they have to offer:
http://www.audiogon.com/cgi-bin/cls.pl?accstwek&1227214894&/Machina-Dynamica-Brilliant-Peb
http://www.audiogon.com/cgi-bin/cls.pl?accstwek&1226674793&/Machina-Dynamica-Clever-Lil-Cl
http://www.audiogon.com/cgi-bin/cls.pl?accstwek&1225716184&/Machina-Dynamica-Codename-Turq
and one of my favs:
http://www.audiogon.com/cgi-bin/cls.pl?accstwek&1227277406&/Machina-Dynamica-Teleportation
Caveat, I have never tried any of these awesome tweaks so I can't vouch for them myself, but word of mouth is a powerful thing...____________________
Pool: Atrium 60's/45's -
.... You will not only think the band is right in your living room, you will actually feel the performers sitting on your lap! It's amazing.
Will that work for The Pussycat Dolls? :eek:____________________
Try it, and let us know what you find out!
