SDA 1.2 XO Mod needed a drill
ben62670
ben62670 Posts: 15,969
edited October 2008 in Vintage Speakers
Well I used a drill this time. I have done a few in the past where I stacked, and glued caps, but I just don't like that. I prefer the appearance if I can lay everything down;) I only needed to drill one hole for the 40uf cap:)
Stock board
DSCN1248.jpg?t=1222824564
All components removed that where to be replaced.
DSCN1246.jpg?t=1222824335
Done
DSCN1249.jpg?t=1222824611
Another
DSCN1251.jpg?t=1222824658
Ben
Post edited by ben62670 on
  • Face
    Face Posts: 14,340
    edited September 2008
    Nice job.
  • ben62670
    Thanks Bro
    The second one is going real fast. Notice anything missing?
    Ben
    Ben
  • Face
    Face Posts: 14,340
    Resistors?
    Did you drill a hole for the large Dayton cap's lead to pass through the board?
  • Systems
    Systems Posts: 14,872
    Great job as usual.;)
    Testing
    Testing
    Testing
  • ben62670
    Face wrote: »
    Resistors?
    Good eye;) I wouldn't have been able to lay the caps down with them on top. Yes I drilled a hole for the 40uf Dayton lead to pass through the board.
    DSCN1254.jpg?t=1222825411
    GV#27 wrote: »
    Thank you sir:)
    Ben
  • ben62670
    Well I am done for the evening. Second one took about an 1 15 minutes. It's nice to have one done in front of you as a template.
    Ben
    Ben
  • hearingimpared
    hearingimpared Posts: 21,136
  • ben62670
    Nice job Bro.
    Thanks Joe. I am really happy that the layout worked. It took some time on the first one, but I feel it was worth it:)
    Ben
    Ben
  • BAD ASP
    BAD ASP Posts: 361
    Beautiful job! Congrats.
    Amp: sunfire cinema grand signature 5ch 425 wpc
    Side surround amp: Sunfire 2 X 300
    Processor: sunfire theater grand V
    Fronts:: polk sda-srs 1.2
    Rears: Polk LSiFX
    Side surrounds: Fxi5
    Center: (2)polk LSiC's
    Sub: svs pb-13 rosenut
    Hd-Dvd: toshiba xa-2
    Blue Ray: oppo bdp83se
    Projector: sony vw60
    Screen: Da-Lite 106"
    APC S20 Power conditioner
  • ben62670
    BAD ASP wrote: »
    I wish the speakers these went in were mine, but this set belongs to another Polkie;) I hope he likes them too!
    Ben
    Ben
  • BAD ASP
    BAD ASP Posts: 361
    ben62670 wrote: »
    Ben
    I can't help it. The speakers are mine and Ben generously agreed to do my boards for me. They do look great, I can't wait to get them back, burn em' in and listen to some really sweet tunes. Thanks a lot Ben.
    Rears: Polk LSiFX
  • ben62670
    No problem. Thanks for having me do them:) I'll should get them out tomorrow.
    Ben
  • BAD ASP
    BAD ASP Posts: 361
    ben62670 wrote: »
    Sweet!
    Rears: Polk LSiFX
  • george daniel
    george daniel Posts: 12,096
    did you "jump" the poly?
    Good night Ben ;)
  • ben62670
    The poly is on the highs. The 12uf feeds the whole top end. I ran the 12 uf straight to the input positive therefore bypassing the poly, and the bypass cap. They where removed;)
    Ben
    Ben
  • zingo
    zingo Posts: 11,258
    Those look great Ben. Nice attention to detail and how everything looks on the board. I couldn't have done it better myself. :p
  • ben62670
    zingo wrote: »
    Hey man I have seen some of your stuff, and your stuff is done nice too:)
    Ben
    Ben
  • hearingimpared
    edited October 2008
    BAD ASP wrote: »
    Don't be surprised if it takes over 300 hours of burnin. My upgrades took over 350 hours before they sounded right.:eek:
  • schwarcw
    schwarcw Posts: 7,358
    edited October 2008
    Ben,
    Real nice job. I don't see the hole for the 40 uF cap lead? Maybe I'm getting a little blind. I like the resistors on the bottom of the PCB. It really helps to clean up the look.
    Carl
  • ben62670
    edited October 2008
    schwarcw wrote: »
    Ben,
    Thanks Carl. The 40uf lead is where I drilled the hole;) The lead is attached on the underside:) I do these real cheap if anyone wants it done.
    Ben
    Ben
  • schwarcw
    edited October 2008
    Now I understand. Real nice! My boards have had the big Sonicaps up in the air and all over the place. Solid, but an interesting geo-art look!;)
    Carl
  • george daniel
    edited October 2008
    nice work Ben,, my boards were like Carls,, caps everywhere,,beside,on top,on the side, underneath,and anywhere else that I could glue them. :eek:
