12V trigger Connection between B&K Ref30 and 5125
MKZ
MKZ Posts: 1,068
I just bought 1/8" miniplug connector from RadioShack but it seems like the amp using RCA connectors. Should I use this 1/8" mini to RCA? Or what kinda connectors using on the amp side? B&K manual saying 3.5mm but doesn't looks like it.
http://www.radioshack.com/product/index.jsp?productId=2103367&cp=
Post edited by MKZ on
  • engtaz
    engtaz Posts: 7,674
    edited September 2008
    No trigger on B&K Ref30. Searched entire manual. Radio shack does sell an ac to 1/8" 6v that will work. You plus the a/c into the 30 then plug the 1/8" into 5215. 5125 need trigger voltage of 5v to 24v. This should work for you.
    engtaz
  • MKZ
    MKZ Posts: 1,068
    The problem was I couldn't plug in 1/8" into 5125. I just went and get that RadioShack 1/8" to RCA and it works now. Thanks.
  • dorokusai
    dorokusai Posts: 25,629
    engtaz wrote: »
    B&K used RCA jacks for triggering back then, for some unknown reason.
