Problem with Clock not updating
tjhyp
tjhyp Posts: 1
edited September 2008 in Troubleshooting
Just bought a I-Sonic2. When I set the time, it shows properly on the screen. But then it doesn't update what time it is, it just sits where I set it. Then if I happen to set the alarm, or turn the alarm off or on, it also updates the time?? So somewhere it is keeping the proper time, just not updating it on the screen?
Any ideas?
Post edited by tjhyp on
  • hoosier21
    hoosier21 Posts: 4,418
    return it for a new one
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • Jed Leland
    Jed Leland Posts: 183
    Hello,
    Being a digital device it could benefit from having the AC power unconnected and reconnected. Give it a try.
    Cheers, Jed
