R30 as surrounds?
styles
styles Posts: 22
edited May 2003 in Speakers
Hey guys,
I'm looking for feedback on using R30s for surrounds vs. the FXi50s. My main use will be for HT in a 5.1 setup.
I've visited CC numerous times but I haven't received any decent help from those guys. The sound room (if you can call it a room) is an open half circle hole in the wall that's not enclosed. They don't carry the FXi50s in store so I couldn't listen to them, only the FXi30s. The R30s sounded pretty nice but they were hooked up as fronts and not surrounds. I've check with other local audio stores but they don't carry Polk.
The R30s are half the price of the FXi50s but I don't want price to be the main determining factor.
Has anyone used both the R30s and FXi50s for surrounds?
Thanks!
Harmon / Kardon AVR 510
Fronts: RT2000I
Center: CSi40
Surrounds: FXi50 *waiting in box
Sub: PSW650
JVC DVD Player
Monster Cables
Post edited by styles on
  • fireshoes
    fireshoes Posts: 3,167
    edited May 2003
    The FXi50's are going to match the sound of your mains better. I would use them
  • styles
    styles Posts: 22
    edited May 2003
    Thanks fireshoes.
    Anyone else?
    Fronts: RT2000I
    Center: CSi40
    Sub: PSW650
    JVC DVD Player
    Monster Cables
  • rs159
    rs159 Posts: 1,027
    edited May 2003
    The FXi's will match your mains better and sound more immersive and open.
    Just buy them! ;)
  • dorokusai
    dorokusai Posts: 25,638
    edited May 2003
    Buy the FXi's.
  • rs159
    rs159 Posts: 1,027
    edited May 2003
    Should we start a poll? ;)
  • styles
    styles Posts: 22
    edited May 2003
    Well, guess that settles it then, FXi50's it is. :)
    Fronts: RT2000I
    Center: CSi40
    Sub: PSW650
    JVC DVD Player
    Monster Cables
