Power back up
dholmes
Do they make a power back-up like for computers that can be used for a ceiling mounted projector? Ive had the power to go off while watching a movie & was worried about the on-off damaging the bulb.thanks
My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
Post edited by dholmes on
Yes, Belkin's Pure A/V line has two different UPS's you can use.
http://catalog.belkin.com/IWCatProductPage.process?Product_Id=195291
http://catalog.belkin.com/IWCatProductPage.process?Product_Id=258472"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
The main thing you need to worry about is the watts. Make sure that you have ups that has enough power to back up the projector. Power Consumption (in Operation) : 265W is my projector and I use the APC Back-UPS RS 1500VA/ 865 Watts, Standalone, 120V, LCD . This like the ones mentioned above have the AVR protection. Plus what ever you plug in to these things are insured. A distinguishing feature of the Back-UPS RS is automatic voltage regulation (AVR). If no one sees it there is no reason to spend the extrta change on the fancy case.
Reciver Pre/Pro - H/K AVR-347
Amplifier - Adcom-7400 5 Channel
Speakers - SRT's
Projector - Sony Avl-aw15 -
Thanks wouldnt that be hard to put on the ceiling?My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
I wouldn't put either in the ceiling in case of a malfunction, etc...
Just get a longer power cord.
As for the units I listed, they can be found on Amazon and elsewhere for half, sometimes less than half of the price listed."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Thanks again! How many min back up should I look for,some of them have 10 min at full & 4 min 1/2 also I should make sure volts & watts exceed the projector.My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
My projector is rated at 240 watts,& it also states that the amps are 2.8a-1.2a what does that mean? Also I found some ups that cost 60.00-100.00 $ as long as the watts match or are greater than the projector it should work am I correct? thanksMy HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
I found a ups for my projector that can handel 300 watts,projector is 240 watt so that should be ok.What I was wondering is can I plug the ups into another surge supp-noise filter,would that hurt anything? thanksMy HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
