Power back up
dholmes
dholmes Posts: 1,136
edited November 2008 in Electronics
Do they make a power back-up like for computers that can be used for a ceiling mounted projector? Ive had the power to go off while watching a movie & was worried about the on-off damaging the bulb.thanks
My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
Post edited by dholmes on
  • Face
    Face Posts: 14,340
    edited September 2008
  • Tollaksen
    Tollaksen Posts: 71
    dholmes wrote: »
    The main thing you need to worry about is the watts. Make sure that you have ups that has enough power to back up the projector. Power Consumption (in Operation) : 265W is my projector and I use the APC Back-UPS RS 1500VA/ 865 Watts, Standalone, 120V, LCD . This like the ones mentioned above have the AVR protection. Plus what ever you plug in to these things are insured. A distinguishing feature of the Back-UPS RS is automatic voltage regulation (AVR). If no one sees it there is no reason to spend the extrta change on the fancy case.
    Reciver Pre/Pro - H/K AVR-347
    Amplifier - Adcom-7400 5 Channel
    Speakers - SRT's
    Projector - Sony Avl-aw15
  • dholmes
    Thanks wouldnt that be hard to put on the ceiling?
  • Face
    Face Posts: 14,340
    I wouldn't put either in the ceiling in case of a malfunction, etc...
    Just get a longer power cord.
    As for the units I listed, they can be found on Amazon and elsewhere for half, sometimes less than half of the price listed.
  • dholmes
    Thanks again! How many min back up should I look for,some of them have 10 min at full & 4 min 1/2 also I should make sure volts & watts exceed the projector.
  • dholmes
    My projector is rated at 240 watts,& it also states that the amps are 2.8a-1.2a what does that mean? Also I found some ups that cost 60.00-100.00 $ as long as the watts match or are greater than the projector it should work am I correct? thanks
  • dholmes
    I found a ups for my projector that can handel 300 watts,projector is 240 watt so that should be ok.What I was wondering is can I plug the ups into another surge supp-noise filter,would that hurt anything? thanks
