Placement question for my FXiA4's
ryanjoachim
http://www.polkaudio.com/homeaudio/products/surround/individual/fxia4/
Technically, the A4's are supposed to go on the wall with (I think it's the tweeter? the side oposite the big speaker) facing the listener.
I decided to do a bit of a switch...I turned each speaker upside down, so that the big speaker is facing the listener instead of the little one.
I think it sounds better, but I could be very wrong...is that **** with my sound stage?
If not, would I need to change the bipole/dipole setting?
"Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
My System:Best Buy is for people who don't know any better. Magnolia is for people who don't know any better and have more money to spend.
TV: SAMSUNG UN55B7000 55" 1080p LED HDTV
HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server.
Post edited by ryanjoachim on
Wouldn't it have been easier to switch left for right to get the speakers on the side you prefer rather than flip them upside down?
Just a thought..............HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
I think I was...slightly less sober at the time...but yes.
The question still stands though!"Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server. -
The flexibility built into the FX line is simply to get the best of both worlds in one design. There isn't really a right or wrong way to set them up, since they were designed to meet both side/rear placement and bi/dipole needs. They were made flexible knowing that few rooms meet the ideal placement requirements.
If my memory serves me, the guidelines for side usage is generally slightly behind and above the listening position using them on dipole with the woofers pointing to the rear.
For rear mounting, the suggested is bipole with the woofers facing each other. Someone chime in and correct me if I'm mistaken, but that is how I recall my FXs working best in those positions too.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Having the woofers face each other sounds best in my room. Play with different positions and see which one sounds best.
Thanks for the responses!
One question I forgot to ask...since I have my FXi4's upside down at the moment, does that effect the sound stage when it comes to where surround tracks are coming from? As compared to being right-side up I mean."Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
I would just run them reverse With the tweeter on top.
