Common ground question
Phil Dawson
Phil Dawson Posts: 288
edited September 2008 in Vintage Speakers
After reading a current thread I am still confused. This is my set up. I have a pair of SDA SRSs in the front bi-amped with PSE mono blocks on the bottom and a PSE stereo amp on the top. In the rear I have 2.3tls bi-amped with a pair of PSE stereo amps. I don't seem to have any problems except that sometimes I develop a feedback problem that can be cured by moving the various inter-connects behind the B&K pre-pro. All of the amps are plugged onto a switching unit giving each amp it's own on/off power switch. The system sounds good except for the occasional feedback problem. What am I doing wrong? (besides the things my wife always brings up)?
Thanks, Phil
Post edited by Phil Dawson on
  • awe-d-o-file
    awe-d-o-file Posts: 146
    A couple of questions> What does the feedback sound like? LF, midrange(1K)? Does it come through all speakers? Are you using SDA interconnects with either/both sets of speakers? You say that you can move interconnects to fix the problem temporarily. Which ones?
    ET
    System: MF Trivista SACD > Placette passive> CJ passive horizontal bi-amp> MF 2500A(LF) MF2100(HF) > 1.2TL's
    Other: Speltz silver Eichmann IC's & speaker wire, Econotweaks Detail Magnifiers, PS Audio P-300(source), R. Gray 600, Al Sekala's AC R/C filters, R. Gray HT PC's, Oyaide R-1's,WPC-Z , M-1, Herbie's & DIY Isolation
    Room: Qty 7 - 4' tall 18" diam. bass traps, Qty 4 - 4' X 2' X 4" panels. All DIY - man my wife is tolerant!
  • Phil Dawson
    The feedback sounds like a 1K tone. This happens mostly when the tuna is in use. I'm not sure which interconnects because of cable ties and the like. When I move them I get a short burst of feedback and then it goes away. It almost seems like I am releasing a built up charge and that doesn't make sense to me. The SDA interconnects are in place. The feed back comes out of all speakers taht are powered up although I think that this has only been a problem in 2 channel modes.
    thanks, Phil
  • ben62670
    ben62670 Posts: 15,969
    Take a multi meter and read between the speaker terminal's grounds. There should be no resistance. Let us know.
    Ben
    Ben
  • Phil Dawson
    Do you mean on each individual speaker as in left and right or between the two terminals top and bottom? I will do that tonight - I won't be back online till AM.
    Thanks, Phil
  • ben62670
    On the amp between the speaker grounds(cables disconnected). It should be near 0 ohms if it is common ground;)
    Ben
    Ben
  • awe-d-o-file
    ben62670 wrote: »
    Ben
    He has monoblocks right? Needs to check continuity between each amps speaker ground. Has anyone ever used monoblocks w/SDA?
    ET
    heiney9 Posts: 25,492
    Yes, many people have. The prerequisite has always been to find out from the manufacturer IF the negative terminals can be tied together to form a common ground. Mono blocks by their nature do not have a common ground.
    You can NOT use bridged mono blocks. That is; a stereo amp that can be bridged to run as a single channel amp. I know of none that when bridged can be made common ground. Plus when you bridge an amp there are serious impedance issues you need to be aware of when running a more difficult load like SDA's or other 4 ohm or less speakers.
    P.s. Using the AI-1 cable supplied by Polk for the models that can use the AI-1 cable solves this problem. Many feel since it's a work around there might be a small decrease in sound quality. YMMV
