What gauge of wire should i use??
Shank265
I have 2 10" kenwood db+ with the polkaudio c500.1 monoblock and i was wondering what gauge wire i should use. i currently have 10 gauge but i was also thinking about putting a capacitor in it. If i put in like a 8 gauge would that be good or should i go bigger? And if so do i need a new altinator for my car because i think it is stock.
Post edited by Shank265 on
some one please help!
Welcome to Club Polk.
I think you might get more responses if you post this in the auto section.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
ok thx
