Subwoofer Shenanigans
wingnut4772
I am setting up my HT and I am brainstorming about my sub position. My backdrop is a freestanding wall in the middle open on all sides.I have two HUGE subs (not pictured)- The SVS PC Ultra/2 and the SVS PC Plus/2.
My idea is to place them behind the wall on the other side (behind) of the HT because it would be too crowded otherwise. I have a channel to pass the cables through so connection won't be difficult. Since the room is basically open should it matter? it's basically the same space that needs to be pressurized.
Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
Post edited by wingnut4772 on
I agree but, .......! If it were me, I would put them on L&R with a custom built shelving system that puts a top slightly above the subs.
FWIW - My rig isn't nearly as dedicated, but if it were, I wouldn't compromise.Make it Funky!
I don't follow...but I am not sure it will be a compromise. It might be pretty cool. I will know when my receiver gets here.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
I think what you're suggesting will work. Freq sweeps/plotting will tell the whole story. I'd recommend you get some bookshelf speakers and sell me your VR4jrs at a great price--but that's just my 2 cents. I think you need to climb out of "your needs" and think about what would be best for your speakers...:DSource: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
With two subs that large you could put them out side on the roof and it wouldn't matter!
Casey
H/T: Epson 6500ub
Sony UBP-X800
Toshiba HD-XA2 (HD-DVD, CD)
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi 10 (bi-amped)
Polk CSi5 (bi-amped)
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
TV Rig: Samsung 50'' 4k display
Polk Signa-1 Surround bar -
I would toss your couch and get a queen size mattress to lay across the subs as a futon.
I think it would work. What way would you face them? Out to the sides, In toward each other or backwards as in car audio away from the HT Wall?
Outward would probably give you good dispersion.
Inward would probably have the biggest bang or should I say boom for the buck. Almost isobarick but limited to directly in front more than dispersed.
That's a neat setup you have there. Can't wait to see it all set up and nice. -
I'm not sure yet. Sideways for sure so they don't stick out into the kitchen. I will have to experiment with the facing directions. I am going to use my SMS 1 for fine tuning.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
Should work fine. Pretty cool idea to provide a back wall there. I like it._________________________________________________
Agreed. It should work very well for music, too. Please let us know.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Dang, how close are the neighbors??? I'm sure by fine tuning with the SMS-1 your placement options open up some what.
That's some serious fire power you have going on there Darla. Congrats & enjoy!! -
might caues a little delay but you should be fine
Thanks guys. Hmmmm do you think it will delay the timing?it's essentially the same room.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
wingnut4772 wrote: »Thanks guys. Hmmmm do you think it will delay the timing?it's essentially the same room.
Don't worry about it. Just do it.
I've heard of other sub setups similar to yours and the results were very positive. Play around with the phase adjustments if you like.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Working on this today. I am pretty much redoing the entire HT so it may not be done by tonight.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
It's not working out. The bass just doesn't sound right. I am really surprised too. I used the SMS-1 and tried every configuration and phase etc and it's just anemic. The readings are much better with them in the front stage but boy is it crowded.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
