poor mans system pics
fbm211
fbm211 Posts: 1,488
edited September 2008 in Electronics
Here are some pics for polkclyde
SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
Post edited by fbm211 on
  • fbm211
    fbm211 Posts: 1,488
    Not much to brag about compared to some of the other stuff Ive seen some of you have but it sounds good and I recently found out one of my cousins does wood working (builds cabinets,furniture,etc) for a living and is going to build me a custom entertainment center for my gear when he has some spare time to do it.And thanks to this forum it will only get better sounding as time goes on.Crossover recap begins next week...
  • PolkClyde
    PolkClyde Posts: 662
    I'll probably will need help in recapping my Crossover or at least where to buy the parts. I thought I saw a thread on that I'll have to go check and look for that thread in Crossover Rebuilding . I think that might be my problem with the right speaker.
    PolkAudioClyde
  • unc2701
    unc2701 Posts: 3,587
    White face 565's??? Hot damn!
    Backburner:Krell KAV-300i
  • Face
    Face Posts: 14,340
    Replace the towel with a curtain, clean the joint up, and do some cable management, it'll look pretty good.
    The white face gear is...interesting.
  • ben62670
    ben62670 Posts: 15,969
    Face wrote: »
    What he said. When you get done there do the same here:eek:
    Ben
  • DollarDave
    DollarDave Posts: 2,575
    Face wrote: »
    I agree, no real offense intended, but if I take picture of my stuff and put it out there for a hundred million people to view on a web site, I pick up the plastic grocery sacks and try to hide a cable or two. I might even put up a clean towel or something. With that said, nice gear.
  • fbm211
    fbm211 Posts: 1,488
    The towel was put up so I wouldnt get the flash reflection.Sorry for the mess,I was moving stuff around cause the system is going to the other side of the room....
  • lakesailor
    lakesailor Posts: 319
    Nothing “poor” about that system. In fact for the money invested I don’t think you could put anything better together period. All of that gear is great value and would costs you thousands to improve upon it if you were buying new. Congrat’s on a nice setup.
    My only caution if you are going to have a custom cabinet built is to ensure you give those amps plenty of airflow – they run hot and really need to breathe. As you know nothing kills components faster than heat build up and bad ventilation.
  • steveinaz
    steveinaz Posts: 19,545
    Very cool, unique stuff.
  • fbm211
    fbm211 Posts: 1,488
    I am going to improve one thing in a few months.>A dedicated transport.Ill be watching audiogoN everyday for a silver Theta data basic II. I did get a good deal on those monos back in 92.Both for 1,000.00 even.New. Now im just trying to get up enough courage to replace the opamps in my DAC to OPA2134s or 2227s.I have 2 of each with adapters to easily swap em out so I can compare different versions. New pics soon.All cleaned up and moved for better accustics.
  • steveinaz
    Don't listen to Oprah and Rachel Ray up there, the towel looks GREAT! :D
  • lakesailor
    fbm211 wrote: »
    Theta makes nice stuff. I have a Theta DAC on order; should hopefully arrive next week at some point.
    Nice score on the amps those are sweet and hard to find in white. !
  • mark090852
    mark090852 Posts: 998
    Hi neighbor. Nice system you have and it sounds like it's just going to get better and better.
    McIntosh MA252 Integrated Amp, LUMIN D2 Network Music Player, Yamaha Aventage RX-A840 receiver, Emotiva XPA Gen3 2 channel amp, Polk LSiM 703 speakers. Oppo UDP-203 Blu-Ray player, Polk LSiM 705 speakers. Polk Signature S20 speakers.
  • engtaz
    engtaz Posts: 7,669
    Sweet setup. Absolutely nothing poor about that setup. Now if you had some RCA speakers, 28 gauge wire and a combo record player/am & fm tuner with 8 track, you would be talking poor.
    engtaz
  • cfrizz
    cfrizz Posts: 13,415
    Agreed Steve!
    You yahoos are always focusing on the wrong thing! I'm looking at the unique gear & you all are looking at the cables! Wierdos!:confused:
    steveinaz wrote: »
  • Face
    Face Posts: 14,340
    Excuse me for liking things nice and neat. :D
  • Roy Munson
    Roy Munson Posts: 886
    There was a time when I would have killed for some white face Adcom amps but I eventually got over it before anyone was hurt.:)
    2 Channel:
    Amp/Parasound Halo A23
    Pre/Carver C-1
    Tuner/Carver TX-11a
    CDP/Jolida JD 100A
    Turntable/AR XB-Shure V15 III
  • doctorcilantro
    doctorcilantro Posts: 2,028
    I'm digging it....
    DC
    For Sale 2019:
    Tortuga Audio LDR passive preamp
    Decware EL34 amp
    Allnic H-1201 phono
    Zu Union Cubes
    iFi iDSD DAC, .5m UBS, iFI Gemini cable, Oyaide Tunami XLR 1.3M, Oyaide Tunami Speaker wire 1.5M, Beyerdynamic DT1990 headphones, PS Audio P3 power center
