Flash drives and PS3
Willow
Can I use one of those Xg portable USB drives in the PS3 to say watch TV shows I have downloaded? so I don't have to burn them on a disk?
Post edited by Willow on
Cause I can get a 4g usb stick fo 9.99$cad. Thisway I could use it over and over less garbage as I have to toss out the DVDs once used..I may just buy it and try, if not it's going back.the stick that is not the PS3
Just make sure the video file formats that you download is supported by PS3.. I don't believe PS3 supports all available video file formats.
they are AVI. which I know it reads on a disk.
I use one regularly on my PS3 for watching divX/avi shows. The PS3 is the best player I have seen yet for these formats. Upconverts them to hi-def as well. I'm using an 8 gig kingston stick.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM
