Flash drives and PS3
Willow
Willow Posts: 11,216
edited September 2008 in Video Games
Can I use one of those Xg portable USB drives in the PS3 to say watch TV shows I have downloaded? so I don't have to burn them on a disk?
Post edited by Willow on
  • haimoc
    haimoc Posts: 1,031
    I never try this, but I am pretty sure it would work.
  • Willow
    Cause I can get a 4g usb stick fo 9.99$cad. Thisway I could use it over and over less garbage as I have to toss out the DVDs once used..I may just buy it and try, if not it's going back.the stick that is not the PS3 ;)
  • haimoc
    haimoc Posts: 1,031
    Just make sure the video file formats that you download is supported by PS3.. I don't believe PS3 supports all available video file formats.
  • Willow
    they are AVI. which I know it reads on a disk.
  • Fongolio
    Fongolio Posts: 3,516
    I use one regularly on my PS3 for watching divX/avi shows. The PS3 is the best player I have seen yet for these formats. Upconverts them to hi-def as well. I'm using an 8 gig kingston stick.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
