In-Ceiling Speaker Installation Question
karaim
karaim Posts: 23
I am installing in-ceiling speakers. I have read that it is good to insulate them. My question is what material can I use to insulate them and where can I buy it?
Post edited by karaim on
  • Eric W
    Eric W Posts: 556
    edited September 2008
    Are you referring to fill type material such as polyfill/fiberglass insulation, or are you looking to contain the sound from bleeding into upstairs? Also what make/model speakers are you using?
    -Eric
    -Polk Audio
  • xeb
    xeb Posts: 31
    i used some leftover mineral wool thermal insualtion i had. polyfill is probably cheaper and easier to get hold of.
