Capacitor Questions
DiscoMike
Hello all !!!
I have been reading about people upgrading their capacitors in the XOs to improve their sound. After reading the posts, I am convinced that the Sonicaps will give the best bang for the buck. I will also be upgrading the resistors to Mills with all the positive feedback I have read. The cost to upgrade all the XOs in my speaks will be over $1000 easly.
After doing some research, seeing other peoples mods, I was wondering how to upgrade other capacitors in XOs when their ratings are 100uF to 600uF, or higher. Sonicap does not make capacitors at these levels. I wanted to know where polkies go to to get capacitors at these high ratings. Stacking capacitors one ontop of another at these levels would be virtually impossible.
Can the capacitors used in XOs these same capacitors be used to replace the capacitors around the power area in stereo equipment ? I am most interested in replacing caps in my power amp and preamp for better capacitors in an attempt to improve great sound for even better sound.
Second topic question - what is the difference in capacitors - electrolytic, vs. film, vs. mylar, etc. When upgrading capacitors in my XO, do I need to upgrade from an electrolytic capacitor to another electrolytic capacitor ? Or can I use a film capacitor as long as it has the same uF rating ?
Third topic question - there is not much info that I came across when it comes to capacitors used in stereo electronics (amp, preamp, ect.). If I am going to upgrade the capacitors in my stereo electronics in an attempt to improve sound, what are some of the best capacitors (ideally best bang for the buck) that anyone have come across ? And where can one go to get these capacitors ?
Thank you all for reading and any imput you can provide.
Disco-Mike
Disco-Mike
Post edited by DiscoMike on
LOL.....yeah good luck.Political Correctness'.........defined
President of Club Polk -
That's foolish. Just buy better speakers. Caps upgrades are considered tweaks; they can't turn water into wine.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
craziness...
The reason for upgrading a cap is because it is IN the signal path.
A cap for a tweeter crossover qualifies. A coupling capactor for the VA stage of an amplifier qualifies. The input coupling capacitor on nearly all amps also qualifies.
A power supply cap does not qualify. -
Caps don't make a difference. Use a piece of string with a wad of chewing gum in the middle (your choice on the color)
Your questions are very broad might be a good idea to get your google on. Sonic caps are a nice choice. And as stated above if they aren't in the signal path don't bother. Also the more complicated the electronic equipment perhaps the more of diminishing returns, as other components (like op-amps to name one) will be the bottleneck then.
Replace caps wisely and use restraint. No use putting a $30 cap in a circuit that has other sound killing components in the same path. X-over are great because most are much, much less complicated than your typical electronic component
That would be shunt capacitors such as the 4.7uf and 1.5uf below. Upgrading the 3.3uf and LF capacitors would make much less of a difference.Replace caps wisely and use restraint. No use putting a $30 cap in a circuit that has other sound killing components in the same path.
