I want to HEAR the bass, not FEEL it!
  • candyliquor35m
    candyliquor35m Posts: 2,267
    edited September 2008
    I'm mainly 2 channel with no subs but use romex for all my 2 channel.
    My HT has a cheap yammie powered sub with just cheap rcas running to it.
    treitz3 Posts: 20,001
    Anybody who may be reading this should take note that using Romex and cheap RCA's will give you a signal. That's a fact.
    It is, however not recommended to bring out your system's full potential. ;)
  • candyliquor35m
    treitz3 wrote: »
    Anybody
    roflol romex is the same concept as anti-cables but better since I use 10 ga instead of their 12 ga.
    I use a cheap rca to my ht sub because I may watch 1 or 2 movies a year :eek:
  • Jeff Beaird
    Jeff Beaird Posts: 217
    PTong88 wrote: »
    Try a better subwoofer with a very rigid design. Also, take for account where you place it in your room.
    Try one of these... you will never go back to direct radiator subs!
    http://www.billfitzmaurice.com/TT.html
    or this monster...
    http://www.billfitzmaurice.com/THT.html
    The Table Tuba is currently residing next to my couch:p
    Thanks, Jeff...
  • curved
    curved Posts: 664
    Maybe you should try looking at a partner for the other sub to mate with :D
    Otherwise, like others are stating, get a BETTER SUB.
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    pfffffffffftttttttttttt............
    you need the Carver Amazings in the Flea Market and a man amp. your room size is not an issue.
    Amatuers.
    RT1--Hardcore without the Bore.
