Did my HK receiver just bite the dust?
iskandam
When I turn on the Harman Kardon it usually displays some text saying what output it's on and what surround mode is on. Today I turned it to stand by mode, then proceeded to turn on the amp. When I turned the receiver on there is no text display, then after several seconds it turned back to stand by mode. I couldn't get it on from stand by mode! What's happening here?
Post edited by iskandam on
Whats happening here? Its the second reported HK failure in a week on these boards. Sheesh....
Fortunately if it cant be fixed (more knowledgable folks here than I), HK has a decent customer service department. I know - I've spent a few days shipping my HK.Do you hear that buzzing noise?
Monster Jam wrote: »Whats happening here? Its the second reported HK failure in a week on these boards. Sheesh....
No kidding! I noticed there has been a lot of bad rap around here for HK recently as well. I'm wondering how old and which models these were however. It does make me look at HK with a more wary eye than before. I hope mine continues to live on. I love it so much.I think Bananas are awesome fruit.
HT: Polk Audio RTi8 x2, Polk Audio CSi5, Polk Audio FXi3 x2, Velodyne DPS-12, Harman/Kardon AVR 247, Samsung 245BW Moniter/TV, Yamaha S1700 DVD/SACD, BJC Optical Cable, 12 guage speaker cable, Monster Standard Subwoofer Cable, Monster Lightspeed 1000 Optical Cable, Z-Line component rack, APC SurgeArrest 11-outlet.
http://www.polkaudio.com/forums/showcase/view.php?userid=81835
____________________ -
Check your speaker cables. I have seen animals chew them into short circuits, wives pull them with vacuum cleaner until they short acrossed the speaker posts, etc. Once the reciever turns with shorted cables, they go into standby as a protect mode.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Posting model numbers usually helps. HK makes tons of receivers. Some of them are known to have failures (specific models).
I own(ed) several HK receivers and amplifiers, and still like HK's sound (although when my Carver TFM-24 will arrive, Citation 24 may go on sale
). Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
I have the AVR 247 that I'm currently using as a pre/pro with the XPA-5. I really only need it until the end of this year until the UMC-1 comes out. I think I should explain from the beginning what happened.
I always turn everything off after I'm done listening. First thing I would turn on is the TV, then source, then the HK, then the amp. This time after turning the receiver to stand by mode I went ahead and turned the amp on. After realizing that I immediately turned the receiver on, and that's when it went to protect mode. It was over at that point.
I called HK cs yesterday and they advised me to unplug everything and just turn on the receiver to see if it works. Same thing. It just kept going into protect mode
Now I'm gonna have to send it back for repair/replacement
