WTB pair of speakerlab HD350 horns
sbjacob77
I am looking for a pair of the horns speakerlab used in there K-horns .Thanks:)
Post edited by sbjacob77 on
You will have better luck finding K-400's and I think you can still order directly from Klipsch.
Although, Last week I seen a pair on fleabay.Thanks, Jeff... -
I tried Klipsch and they do have that horn,now the K-401 plastic, but they will only sell to you if you have a pair of La scalas or Klipschorns with serial # that had K-400 metal horns and you wanted to upgrade to the plastic .Some think the plastic horn sounds better than the metal. thanksJeff Beaird wrote: »You will have better luck finding K-400's and I think you can still order directly from Klipsch.
Although, Last week I seen a pair on fleabay. -
Some think the plastic horn sounds better than the metal. thanks[/QUOTE]
The cast aluminum horn used to resonate. Just wrap it w/Dynamat or some sound absorbing material. If you join the website they don't ask stupid questions like that. Talk to Micheal Coultier, he works @Klipsch oops! not any more, and was very helpful.
I PM'ed him.Thanks, Jeff... -
Here you go..!
http://seattle.craigslist.org/see/ele/824579596.htmlThanks, Jeff... -
Thanks for the info Mike has hooked me up in the past.I wish I had more room but with 2 new pairs of La scalas I built and KG5's, 901 VI's, JBL's and Polk M10's...:rolleyes:I do have room for some smaller speakers.Well I will keep my eyes on Ebay .:)Jeff Beaird wrote: »Here you go..!
http://seattle.craigslist.org/see/ele/824579596.html -
Well you were correct I got a pair on Ebay today:)
