Sunfire signature ll
snow
Well I have decided after much thought to try and get a Sunfire signature ll amp after purchasing a Carver research Lightstar direct pre. Most likely the the 300 wpc non signature model would be all I will ever actually need, but I figure why not go for the bigger model since there is one that popped up on ebay that looks to be in decent shape.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=130248811422&ssPageName=STRK:MEWA:IT&ih=003
And it should be interesting to compare the combinations of balanced and rca style inputs with the current and voltage outputs.
REGARDS SNOW
REGARDS SNOW
Well, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
Post edited by snow on
COOLNESS!!!
I can't wait to read your reaction to it!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
It's a great amp - good luck!Main System: Polk SDA SRS 1.2 Speakers, Sunfire Signature 600~two Amp, Carver C-16 Preamp, Carver TX-11b Tuner, Marantz 6350Q TT, Philips CDR-775 Recorder, Teac V-707RX Cassette Deck, Signal Cable Double Run Speaker Cable
Upstairs Den: Marantz 2325 Receiver, Marantz 5220 Cassette Deck, Marantz HD-880 Speakers, Marantz 6370Q TT
Exercise (Kabuki speaker) Room: Kenwood KR-9600 Receiver, Pioneer CS-99a Speakers, Sansui SP-X9000 Speakers (not pretty, but LOUD!
Thanks guys and Cathy. I havent won this auction yet but if I do I will certainly let my thoughts be known here. I think that this is the best way to learn about a product is through another audio nuts views, even though there has been plenty of reviews by the pros its always interesting to read an non professional point of view.
REGARDS SNOWWell, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
Not a review per se ... But I've had a pair of these for a couple of years and have no reason to change ...
Has anyone tried the sunfire amps with a tube pre? I wonder if the combination sounds as good as with a carver amp.
from what i have read it should sound even better.
Well I didnt get this amp it went for a litle more than I wanted to spend considering the condition of the pics. But I am continuing to look for either the 300x 2 or 600x 2 in very good to near mint condition
Awww that's too bad. But you'll get one!
Well my 2 Sunfire pieces are all packed up. Hopefully they will survive the move & unpacking!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
