Sunfire signature ll
snow
snow Posts: 4,337
edited September 2008 in 2 Channel Audio
Well I have decided after much thought to try and get a Sunfire signature ll amp after purchasing a Carver research Lightstar direct pre. Most likely the the 300 wpc non signature model would be all I will ever actually need, but I figure why not go for the bigger model since there is one that popped up on ebay that looks to be in decent shape.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=130248811422&ssPageName=STRK:MEWA:IT&ih=003
And it should be interesting to compare the combinations of balanced and rca style inputs with the current and voltage outputs.
REGARDS SNOW
Post edited by snow on
  • cfrizz
    cfrizz Posts: 13,415
    COOLNESS!!!
    I can't wait to read your reaction to it!
  • SDA SRS 1.2
    SDA SRS 1.2 Posts: 255
    It's a great amp - good luck!
    Main System: Polk SDA SRS 1.2 Speakers, Sunfire Signature 600~two Amp, Carver C-16 Preamp, Carver TX-11b Tuner, Marantz 6350Q TT, Philips CDR-775 Recorder, Teac V-707RX Cassette Deck, Signal Cable Double Run Speaker Cable
    Upstairs Den: Marantz 2325 Receiver, Marantz 5220 Cassette Deck, Marantz HD-880 Speakers, Marantz 6370Q TT
    Exercise (Kabuki speaker) Room: Kenwood KR-9600 Receiver, Pioneer CS-99a Speakers, Sansui SP-X9000 Speakers (not pretty, but LOUD! :) )
  • snow
    snow Posts: 4,337
    Thanks guys and Cathy. I havent won this auction yet but if I do I will certainly let my thoughts be known here. I think that this is the best way to learn about a product is through another audio nuts views, even though there has been plenty of reviews by the pros its always interesting to read an non professional point of view.
    REGARDS SNOW
  • PolkWannabie
    PolkWannabie Posts: 2,763
    Not a review per se ... But I've had a pair of these for a couple of years and have no reason to change ...
  • candyliquor35m
    candyliquor35m Posts: 2,267
    Has anyone tried the sunfire amps with a tube pre? I wonder if the combination sounds as good as with a carver amp.
  • jjwm27
    jjwm27 Posts: 123
    from what i have read it should sound even better.
  • snow
    snow Posts: 4,337
    Well I didnt get this amp it went for a litle more than I wanted to spend considering the condition of the pics. But I am continuing to look for either the 300x 2 or 600x 2 in very good to near mint condition :)
    REGARDS SNOW
  • cfrizz
    Awww that's too bad. But you'll get one!
    Well my 2 Sunfire pieces are all packed up. Hopefully they will survive the move & unpacking!
