Parasound HCA800 II and Audiosource amps for sale
jwhitakr
I have for sale a total of three home theater amplifiers:
1) Parasound HCA-800II 2 channel amp. $125 firm + shipping
This is in very good condition, no marks or any scuffs on the face plate. I would rate it conservatively as a 7/10 condition. You can see from the first two pictures that it is in great condition. This is one of the early models from their HCA line.
It can be run in 2-channel or bridged mono with 8ohm speakers. This was my first real amplifier and I hate to see it go, but I need to sell it to raise some funds. Includes original owners manual.
Specs:
Continuous Power Output - Stereo
100 watts RMS x 2, 20Hz-20kHz, 8ohm
150 watts RMS x 2, 20Hz-20kHz, 4ohm
Continuous Power Output - Mono
260 watts RMS, 20Hz-20kHz, 8ohm
Current Capacity 28.3 amperes continuous
40 amperes peak, up to 200msec.
Slew Rate 60V/m second
Frequency Response 8Hz-90kHz, +0/-3dB
Total Harmonic Distortion < 0.08% at full power, < 0.03% typical levels
Full specs can be found at this link.
2) I have two (2) Audiosource 100 amplifiers. $65 each + shipping
Both are refurbished units that work great and provide a very nice step up from AV receivers. They can each be run in 2-channel mode or bridged. There is one scratch mark on the left side of one of the units, but both faceplates are very clean and don't have any scratches or scuffs. I would conservatively rate the one with a scratch as a 6/10 condition and the one without a scratch as a 7/10.
Specs:
- Power Output: 8 ohm stereo 50W x 2
- 8 ohm bridged 150W x 1
- Frequency Response: 20Hz - 20kHz +1dB/-0.5dB
- Signal to Noise Ratio: 101dBA at 8
Specs:
Specs:
My HT
HDTV: Panasonic PT-61LCX65 61" Rear Proj. LCD
AVR: Harman Kardon AVR 235
Video: 80GB PS3, Toshiba HD-XA1 HD DVD
Fronts: Polk Audio RTi8
Center: Polk Audio CSi3
Amp: Emotiva LPA-1
Surrounds: Polk Audio R150
Sub: HSU STF-3
The only true barrier to knowledge is the assumption that you already have it. - C.H. Dodd
Amp: Emotiva LPA-1
Sub: HSU STF-3
Post edited by jwhitakr on
First two pics are the Parasound, next 2 pics are of the Audiosources.
My HT
Amp: Emotiva LPA-1
Sub: HSU STF-3
The only true barrier to knowledge is the assumption that you already have it. - C.H. Dodd -
Perhaps I need to resort to some retail-store-gimmicky-pricing to move this merchandise ...
Labor Day weekend special!
Both Audiosource amps for $120 + shippingMy HT
Amp: Emotiva LPA-1
Sub: HSU STF-3
hmm, already own the parasound but wouldnt mind having another. but, i have not figured out how to use the bridge mode. any help?? and shipping to 98327
Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC -
Bridging it to mono is real easy assuming that you are using an 8ohm speaker. There's a switch on the back that you have to set to "Mono", and then just connect your speaker wire to the red positive connectors. That's all there is to it - and then you've got a clean, excellent sounding 250w of power!
Shipping to 98327 would be about $25.My HT
Amp: Emotiva LPA-1
Sub: HSU STF-3
that's what i thought but the switch is missing on mine
beeeeeeeyumpMy HT
Amp: Emotiva LPA-1
Sub: HSU STF-3
Quick question on the Parasound, would this be adequate or overkill for a CSi5? Also how about shipping cost to 92173. Thanks in advance!
I think it would be pretty bad **** if you bridged it for a CSi5. It would probably help out a lot with the clarity of dialogue in movies. You might just want to use an SPL meter to make sure all the levels of your speakers are where you want them to be though. That way your center doesn't stand out and ruin the surround experience.
slikpolk - The Parasound would work great bridged to a CSi5. I can say that it absolutely made my RTi8's sound great when it was running in stereo, so feeding all the power to your center channel would really make sound effects and dialogue come to life.
Shipping to 92173 would be about $22. Let me know if you are interested!
Airplay - Spot on advice.
My HT
Amp: Emotiva LPA-1
Sub: HSU STF-3
Last price drop before heading off to Fleabay.
Parasound: $105 + shipping
Both Audiosource amps: $110 + shippingMy HT
Amp: Emotiva LPA-1
Sub: HSU STF-3
how much shipping for the parasound to 98327?
how much for the two audiosource amps?
i found the switch for the parasound but the bridged connectors in the rear are broken so would need to be fixed before i could bridge it. ya wouldnt happen to want a nice tuner or something in partial would ya?
ill take the parasound for my csi5.. im in kansas city.. where are you?
Shipping to 98327 would be about $25.starkiller wrote: »how much shipping for the parasound to 98327?
Bruss has dibs on the Parasound.
For the two Audiosource amps, I'll let them go for $130 shipped. That's a steal!
Let me know. My HT
Amp: Emotiva LPA-1
Sub: HSU STF-3
PM coming your way.My HT
Amp: Emotiva LPA-1
Sub: HSU STF-3
Picked up the parasound yesterday and cut it in this morning. My center has improved a ton. crisp clean dialogue. This amp looks brand new, great piece of gear jwhitakr. Im very pleased
