SL4000 tweeters
musogazza
Hi, I have a pair of Polk mini's. The tweeter in one has failed and was wondering what tweeter would work as a replacement?
Thanks!
Thanks!
Post edited by musogazza on
Your best bet is to call Polk direct and ask them.Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors** -
Before you do anything you might want to swap the bad tweeter with the good one to make sure it's the tweeter that's failed.
