Placement for the center channel speaker
Chameleon2
Chameleon2 Posts: 112
edited September 2008 in Basic Hookup/Wiring Questions
Hello, long time Polk Audio owner, first time poster here - nice forum.
The question I have is for my mother's setup.
She just got a 46" Panny plasma and is looking to setup a nice surround-sound system.
The TV is setup above a gas fireplace (I know....:eek:); no place for the center speaker above the TV and not much room in front of the TV (which sits up on it's own stand).
Looking at getting the CS10 (6.5hx20wx9.8d); would it be completely insane to place the speaker behind the TV?
The only other option would be to have it well off-center which is obviously not ideal.
She already has satellite speakers (can't recall the model #), but will be getting a PSW-110 subwoofer and an Onkyo TX-SR606 receiver.
Another question; I have as early 1990's subwoofer, model RM1000W and RM3000 satellites; couldn't find any specs here....anyone have info on these speakers?
thanks
Post edited by Chameleon2 on
  • tcrossma
    tcrossma Posts: 1,301
    edited August 2008
    Behind the TV I'd have to say is no good, and off-center is much less than ideal. If there's no room below, how about above tilted down?
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • Chameleon2
    edited August 2008
    okay, have it suspended from the top of the cabinet angled downward...hmmm. interesting.
    Will have to check that out this weekend.
    thanks!
  • thunders
    thunders Posts: 7
    edited August 2008
    I placed a CSi5 behind my Samsung LCD facing up due to a simular tight setup situation. They both sit on the bedroom dresser which is almost 5 feet above the floor. This was a huge improvement from the factory TV speakers which face the wall to the rear of the TV. I'm very happy with the set up. Absolutely no complaints about the looks either.
    I also have the Onkyo TX-SR606 receiver and used automatic set up for the system.
    So check it out both ways.
  • McLoki
    McLoki Posts: 5,231
    edited August 2008
    Are in-wall speakers an option? (not sure if your gas fireplace vents through a chimney or not)
    Assuming the answer is no - I think your best bets would be:
    1 - phantom center. (no center at all, just play with your front speakers. Depending on placement of your fronts in your room and relation to your seating position - this can vary from exceedingly good to less than ideal. (in my room, unfortunately it slides closer to the less than ideal side of things)
    2 - mount the center below the TV on a floating shelf or with a bracket. (I recommend below the TV based on the fact that the tv is above a fireplace so is probably pretty high already.
    3 - mount the center above the TV on a floating shelf or with a bracket. (this is how mine is set up and I can tell you from experience - it can sound pretty good, but as you get closer than a foot or so from your ceiling - sound quality starts to suffer. Even with the speaker tilted twords your listening position.)
    Michael
    Edit - Forgot to answer you questions....
    1) behind the TV is thinking outside the box, but a really bad idea.
    2) Off center would work, but running a phantom center (option 1 above) would provide better sound than a center speaker to the side of your TV.
    3) Welcome to Club Polk. :)
  • Chameleon2
    edited August 2008
    For mounting the speaker above the TV, any recommendations on a commercially available bracket that can mount to the "ceiling" over the TV? The TV is in a large, wood-paneled space with shelves on either side (and the gas fireplace & hearth underneath).
    Mounting the speaker below the TV would put it in front of the fireplace which doesn't sound like a hot idea either.:rolleyes:
  • McLoki
    McLoki Posts: 5,231
    edited August 2008
    Can you post a picture of the intended location? May help.
  • Chameleon2
    edited August 2008
    I'll try and get a pic tomorrow; in the mean time....
    The room is fairly large and "open" to the sunroom, dining room and so on. Would the RMC8 center speaker have enough umph?
    It's small size would allow it to be placed in front of the TV with no problems.
    Specs are dual 2-1/2" woofs with 3/4" tweeter; 20 to 125 watts, 89db.....
    thanks.
  • McLoki
    McLoki Posts: 5,231
    edited August 2008
    What are you running for front speakers again - I really think phantom center may work best in your room based on what you are describing. (certainly better than a mis-matched and undersized center)
  • cwhyte
    cwhyte Posts: 27
    edited August 2008
    McLoki wrote: »
    +1, do without the center if you can't find an ideal mounting situation
  • Face
    Face Posts: 14,340
    edited August 2008
    McLoki wrote: »
    Good suggestion. Some of us prefer running in phantom mode opposed to physically having a center channel.
  • Erik Tracy
    Erik Tracy Posts: 4,673
    Does the Panny have built it speakers?
    Just stirring the pot for ideas, but what if you fed the center output from the avr to the plasma built it speakers?
    Something to consider.....?
  • Eric W
    Eric W Posts: 556
    Erik Tracy wrote: »
    I'd rather have NO center channel then use the TV speakers as the center channel. The TV speakers are vastly inferior to almost any outboard audio system's speakers and it'll make the system sound horrible. All too often, users will "force" the system into being something that it really can't accommodate properly due to space or other constraints. The center channel and rear speakers of 7.1 come to mind quickly. Sometimes it's better not to do it at all, then to do it the wrong way. But in the end, it's your ears and your system :)
    -Eric
    -Polk Audio
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    how about an in-ceiling install, lots of nice Polk Products available.
    RT1
  • Chameleon2
    12 foot high ceiling...
  • reeltrouble1
    may still work just fine, you just have to balance the speaker pressure level to the listening position, you can aim the tweeter, I would contact Polk and let them know the situation, afterall, they are the speaker specialists..........
    RT1
  • Chameleon2
    purchased a Sony VCS10 center speaker - just to try it, if nothing else.
    size: 21-1/2 wide x 3-1/4 high x 6 inches deep.
    4 2-1/2 mid-range speakers rated at 100watts.
    will hook it up this weekend (weather permitting).....
  • Chameleon2
    oops, make that a Bose VCS-10 center speaker.
    (why can't I edit my own posts :mad:)
  • PTong88
    PTong88 Posts: 37
    Head to Home Depot and buy some L-brackets. Attach one end to the bottom of the edge of the mantle of the fireplace if you can and use machine screws to attach the center channel to the brackets. You may have to drill the holes on the L-bracket to make the diameter larger.
    ONKYO TX-SR606
    polkaudio RM30 (Cntr)
    polkaudio RM7400T (Frnt L & R)
    polkaudio RM6902 (Surr L & R)
    polkaudio RM 6901 (Rear L & R)
    polkaudio DSW Pro 400 Sub (Front & Rear Sub)
    SAMSUNG HPS-5053, APC C2
    Microsoft XBox 360 Elite, Microsoft Xbox, SONY PlayStation 3, SONY Playstation 2, Nintendo Wii, SNES, Nintendo
    SONY CDP-CX455, SONY CDP-NC85H
    Monster HTS 5100 SS MKII, Monster PowerCenter SW 200, Monster PowerCenter AV 200
    Logitech Harmony 550
  • NotaSuv
    NotaSuv Posts: 3,871
    Did you try it with no center channel?
    I think no center would be better than the VCS
    cousin bought one and ended up using it for 3 hours before bringing it back........
