Marantz 510
natehack
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=320290503042
This amp really bring this much? I searched and the retail was around 600 or so. Must be a sweet rig. Researching vintage amps and speakers kept me up until 1 last night... do I have a problem?
Denon AVR5700 doing work
Polk RTi10 pumped by Carver TFM-35
Polk CS1000p
Mission 760
B&W ASW750
Polk CS1000p
Mission 760
B&W ASW750
Post edited by natehack on
Marantz Power Amps are very much collected by the vintage Hi Fi group.
I dont know where you got your info but the Marantz dealer list shows it as 899 in 1975. I believe that was the MSRP on it.
It is a fine amplifier at 256w/ch for 2ch at 8 ohm 350 at 4 ohm. Specs show THD at .05 at 256 watts and .1 at 350.
Now what is that worth?
I bet it goes for about 7 bills.:eek:http://www.billbeau.net
Carver
Twin M400 Power Amps
Pioneer
SA-9500II RT-909
TX-8500II CT-F1000
SG-9800 PL-518
RG-1 PL-540
PDR-609
SAE
5000
5000A
DBX
224
228
400X
400XG
Infinity
Qe 2-way Speaker -
Are they highly collected because of rarity or clean sound or because they look beefy?Denon AVR5700 doing work
Polk CS1000p
Mission 760
B&W ASW750 -
Im not sure on rarity. They do come up on Ebay now and again. Alot of the lower wattage ones show up alot. Havnt seen many on Craigs List. Marantz is a well built amplifier as well as most of there equipment.
I had a reciever from them back in 1974 and it was a nice amp.
This one happens to be just down the freeway from me. Hmmmmmm im looking for some beef for my system hmmmmmmm I could save 50 bucks by picking it up.
Should I wait for a Pioneer Spec 4 or Spec 2 ooooorrrrrr pick up the Marantz?
Ohhh the horror the horror:ohttp://www.billbeau.net
Carver
Pioneer
SA-9500II RT-909
TX-8500II CT-F1000
SG-9800 PL-518
RG-1 PL-540
PDR-609
SAE
5000
5000A
DBX
224
228
400X
400XG
Infinity
Qe 2-way Speaker -
Should you wait?!?!? Nah, do work and tell us how it goes!!Denon AVR5700 doing work
Polk CS1000p
Mission 760
B&W ASW750 -
If I go and get the Marantz that pumps 250 watts then I have to upgrade my speakers. The Infinity Qe's are rated at 100 watts. Hmmmmm
Do I see a set of Polks in my future or maybe some Klipsch RB-81's
The Pol LS19's are rated to 200 watts but there also rated at 4 ohms. This pushes the Marantz to 350 watts. Now the efficiency is 88db but with 350 watts we dont need to worry about that.
Now the Klipsch RB-81 is rated to 150 watts and at 8 ohms. Lower price tag and the efficiency is 97db.:cool:http://www.billbeau.net
Carver
Pioneer
SA-9500II RT-909
TX-8500II CT-F1000
SG-9800 PL-518
RG-1 PL-540
PDR-609
SAE
5000
5000A
DBX
224
228
400X
400XG
Infinity
Qe 2-way Speaker -
Hmm... what speakers and amp to get.
Sounds like the type of problem I like to have:)
Good luck and keep us posted.Denon AVR5700 doing work
Polk CS1000p
Mission 760
B&W ASW750 -
Your amp and speakers don't have to have the same rating.
Your amp needs the extra wattage to handle the transients
without clipping, which is what causes most speaker damage.
As long as you don't try to push the speaker's to their rated
capacity, you'll be fine. I would hope you couldn't listen at
a 100 wpc RMS!"The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson
