One amp vs. Seperate amps
REDWING3139
REDWING3139 Posts: 44
edited September 2008 in Basic Hookup/Wiring Questions
Hello
I was wondering if some one could tell me what are the advantages and disadvantages of using one amp with multiply channels or seperate amps for each channel.
thank you for your help
Post edited by REDWING3139 on
  • zingo
    zingo Posts: 11,258
    edited August 2008
    A multi-channel can save you space since all channels are in one chassis, but it is also very heavy. Moving 5-7 channel amps is not a fun task. You also have to deal with 5-7 power plugs instead of one, which takes up a lot of outlet space. Plus, if you use aftermarket power cables, 5-7 channels is a fair amount of money on those. However, if something happens or goes wrong with a monoblock, it's easier to fix/have fixed than a large multichannel amp.
    You also need to look at your budget and if monos fit into it since they can be pricey depending on what brands/models you're looking at. For example, a 7 channel, 200wpc Outlaw amp is $2149, where as the same specs for 7 monoblocks would run you $2450.
  • SolidSqual
    SolidSqual Posts: 5,218
    edited August 2008
    I would go with separates whenever possible. But, you can choose however extreme you want to go. Most people are limited by funds and space.
    Personally, I have four monoblocks for my two channel setup alone. That was an improvement from two stereo amps for each speaker.
  • Willow
    Willow Posts: 11,229
    I went to mono route the first time. If I had to do it all over, I'd still go mono but do to space, I think next purchase will be a multi-ch amp.
  • TNRabbit
    TNRabbit Posts: 2,168
    "one amp to rule them all...."
    :d
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • just_visiting
    just_visiting Posts: 40
    I run 2 separte amps in a 5 channel setup. A 2-Channel for my fronts and a 3-channel for my centre and surrounds.
    Display: Sony XBR3 46"
    Pre/Pro: Marantz AV7005
    Amplifiers: Anthem MCA20 / Anthem MCA30
    CD: Pioneer Elite PD59 / Sony XA20ES / Denon 755AE
    DVD: Denon 3930CI
    BD: Pioneer Elite 05FD
    Sat: Bell TV 9241HD
    Game: Sony PS3 60GB
    Media Streamer: WDTV Live Hub
    Power Console: Panamax 5300PM
    Speakers: Paradigm Reference Studio v.3
    Subwoofer: SVS 16-46PC+
    Preamp: Parasound P3
    Amplifier: BAT VK60 Tube
    Sacd: Sony 777ES
    Power Console: Ultralink PGX-500
    Speakers: Paradigm Reference Studio 20 v.5
  • leadfoot1
    leadfoot1 Posts: 155
    I run a multi-channel for my surrounds and have just purchased a quality 2 channel for the mains. That way the setup can (hopefully) double as a decent 2 channel rig too.
