a quick queston about modifying my polks
goingganzo
i want to upgrade to a better speaker but if i buld my own i need a new amp and if i get the new ls i need a new amp. my thought was to get the vifa ring tweet like usaed in the new ls line and install it in my 800i/400i what do you think? worthe the time or waste of time?
Post edited by goingganzo on
Possibly a waste of time unless you know how to redisign your crossover. You can't just throw some speakers in the box and hope that they work well together if the X-over isn't designed properly. Plus you're going to stick a 4 Ohm tweet in an 8 Ohm box. I wanted to do that a while back and had a post in the forum about it. It got ugly...Damn....8 lines...I've gotta put my sig on a diet now....
i would not be that bad depends on how complex the xo is. it could be as easy as changeing 2 resistors i just want to know if it will fit.
For the guy that fully constructed his own subwoofer, I would think that the 'fit' question would be the last thing that would prevent you from doing something like this.......
I remember Tony's thread about this, and I've called Ken at C.S. before to ask him if I could do the same with my RT16's and he flat out, and was almost offended at the question, said NO. I looked at the Vifa site and it didn't look like they had an 8 ohm ring tweeter, but they do have 8 ohm dome tweeters if I remember correctly.comment comment comment comment. bitchy. -
A forum member did do just this, and he had to modify the baffle on the RT series speaker slightly to make it fit.
I personally wouldn't do it, but don't let the 4ohm rating scare you away, a 4ohm resistor in line with the tweeter will bring it to 8 ohm, if thats what the network is looking for.
Cheers,
RoosterCheck your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
Not a good idea Tweaking the tweeters in your RT800i
and CS400i or RT16 for vifa? WTH are you thinking...
RT series speakers tweeters are made of Tri-Laminate Dome
similar to the SL3000 materials.
I, for one, still love the the sound of these tweeters.
Har -
True, electrically this is sound, however sonically, you're robbing the power that the Vifa Ring Tweeter need to perform as is should. The true answer here is how do you get the whole rig down to 4 ohms. However, chances are, if you double the power to the speakers, they may go POOF....if you exceed the max wattage.Damn....8 lines...I've gotta put my sig on a diet now.... -
the thing is i just want to try sothing different. i want to upgrade but i have a catch 22. i can upgrade my speakers but my amp wont handle the 4 ohm load so i have to upgrade my recever by adding a amp. i was looking at a diy setup useing the vifa tweet. it is a mtm setyp with a 8 in woof and the ring tweet. they look real nice. and have gotten rave revews.
HUH?!?!?!?!?!?!comment comment comment comment. bitchy. -
Originally posted by brettw22
HUH?!?!?!?!?!?!
ROFLMAO!! -
I tend to agree about just adding a resistor in series with the tweeter. With the current it sees halved its designed output would have to be reduced. Ditto the comment about the crossover not matching. But I have to go find that ugly thread you mention and see what the issue was there.
Gonzo,
If you want to mod your Polk's and they are out of warranty, why not try? You can go back to stock, if you don't like the results.
Then again, you built your sub. Why not buld a pair of speaks from scratch?More later,
Tour...
Vox Copuli
i wanted to get a listen to the tweet. i dont have a local dealer that sells the ls line. and the other problem is the speakers that use the ring tweet are usaly 4 ohms. so i have to upgrade the amp first
this is the speaker type i was looking at
http://www.t-3.cc/users/audioworx/page113Tibor-MTM.html -
ganzo, link didn't work, but I get the idea now. Did not intially think about the circuit impact of adding a 4 ohm tweet in parallel with an 8 ohm mid/bass. It would drop the apparent impedance to 2.67 ohm.
Yup, amp time for you.More later,
Tour...
Vox Copuli
here is a pic off the link i dont know the size. i am not too fond of the finish but this is a general look of the woofers and tweets.
how come it is not ataching the pic?
Link works fine for me.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
In general, changing drivers in a speaker SYSTEM is not as easy as it is being made out to be, and rated nominal impedance of a different tweeter compared to the rated nominal impedance of the *system* or the woofer is hardly the overpowering concern. For a quality speaker system, the crossover design is an integral part of the design process for the entire system. It isn't just a matter of putting together an electrical crossover at some frequency and throwing in a couple of drivers that have the same impedance. For that approach, you might as well buy an off-the-shelf crossover... and if it were that easy, what the hell are we all doing throwing our money away on premade speakers from Polk or any other company?
In fact, the Hi-Vi/Vifa design at that link has two drivers with different impedances.. the ring tweeter is 4 ohms nominal, the woofer is 8 ohms nominal. Those impedances, as well as many other characteristics of each driver.. voice coil inductance, DC resistance, etc. .. as well as adjustments such as a Zobel network, are all factored into the design from the very beginning.
Parts Express has a featured design using the ring tweeter and a Vifa woofer. Perhaps that would be a good place to start if you want to utilize that tweeter, get into DIY beyond subs, AND to some extent add some assurance as to the result.
http://www.partsexpress.com/projectshowcase/nebula/nebula.html
