SDA ID and tweeter issues
dougiefish1963
dougiefish1963 Posts: 7
edited August 2008 in Vintage Speakers
Can anyone identify my new speakers, I believe they are the SDA 2's. Also uppon arrival, I found the right channel tweeters not working, where's a good place to start in troubleshooting. The units have 2 side by side tweeters, 3 drivers and a passive radiator. I got these on EBAY for $127.00 AND THEY ARE VISUALLY MINT!!
Success is in the Attention to Details!
51" Samsung Plasma
RX-V863BL Yamaha 980 watt A/V Reciever w/ I-Pod dock
Yamaha 6 disc cd player
Polk SDA 2 fronts
Klipsh F-1 sides (used to be frontd till the Polks arrived!)
Klipsh C-2 center
Klipsh S-2 rears
MTX 12" 250 watt sub
X-Box 360
Post edited by dougiefish1963 on
  • ben62670
    ben62670 Posts: 15,969
    edited August 2008
    First welcome to Club Polk.
    Those are the original 2's. There may be fuses on the backs of those. Were you able to check for them?
    BTW nice snag!
    Ben
    Ben
  • PolkClyde
    PolkClyde Posts: 662
    edited August 2008
    Because of that tweeter I don't think that the speaker in question are not very well love here in the Polk family.
    PolkAudioClyde
  • dougiefish1963
    edited August 2008
    yes, there are no visible fuses or resets. and thanks for the welcome
    51" Samsung Plasma
    Polk SDA 2 fronts
    Klipsh C-2 center
    Klipsh S-2 rears
    X-Box 360
  • Face
    Face Posts: 14,340
    edited August 2008
    Swap the tweeters from one cabinet to the other. If the tweeters still don't work in that cabinet, it's probably the poly switches located on the crossover.
  • dougiefish1963
    edited August 2008
    Kinda what I figured. Thanks Face. Are parts readily available for these and where would I get tthem?
    51" Samsung Plasma
    Polk SDA 2 fronts
    Klipsh C-2 center
    Klipsh S-2 rears
    X-Box 360
  • dougiefish1963
    edited August 2008
    PolkClyde wrote: »
    Why's that Clyde? They are beautiful and even with the lack of right tweets, sound fantastic!
    51" Samsung Plasma
    Polk SDA 2 fronts
    Klipsh C-2 center
    Klipsh S-2 rears
    X-Box 360
  • Face
    Face Posts: 14,340
    edited August 2008
    Yes, you can get them from Polk. But, if you're using a nice amp to power them, you can probably get away with bypassing the poly switches as some of us have.
    Most find the old tweeters bright and beemy. The new replacement tweeters are much smoother.
  • candyliquor35m
    candyliquor35m Posts: 2,267
    edited August 2008
    Nice speaks and tweeters ;)
  • Ron Temple
    Ron Temple Posts: 3,212
    edited August 2008
    Do you have the interconnect cable? The dimensional tweeters and drivers won't work without it.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • dougiefish1963
    edited August 2008
    I am using a new RX-V863BL Yamaha A/V reciever with 105 wats per channel 980 total watts
    51" Samsung Plasma
    Polk SDA 2 fronts
    Klipsh C-2 center
    Klipsh S-2 rears
    X-Box 360
  • Face
    Face Posts: 14,340
    edited August 2008
    In that case, replace the switches, don't bypass them.
  • dougiefish1963
    edited August 2008
    Ron Temple wrote: »
    yup sure do
    51" Samsung Plasma
    Polk SDA 2 fronts
    Klipsh C-2 center
    Klipsh S-2 rears
    X-Box 360
  • dougiefish1963
    edited August 2008
    Thank you all so much for the help and quick responses
    51" Samsung Plasma
    Polk SDA 2 fronts
    Klipsh C-2 center
    Klipsh S-2 rears
    X-Box 360
    F1nut Posts: 51,926
    edited August 2008
    Face wrote: »
    Nice code....;)
  • Joe08867
    Joe08867 Posts: 3,919
    edited August 2008
    I would suggest disconnecting the dimensional tweeter and trying them that way also. You may find them not to be as harsh.
    These look just like mine except I have the silver face tweeters.
  • candyliquor35m
    edited August 2008
    Have you swapped the working and non-working tweeters yet?
    sl2000's are easy to find. Just ask here or in a WTB (Wanted) thread if it turns out to be bad tweeters.
  • michaeljhsda2
    michaeljhsda2 Posts: 2,201
    edited August 2008
    Were the speakers shipped to you? If they were there is a very good possiblilty that the magnets broke off during shipment and are laying in the bottom of the speaker cabinet. I should know because this happened to mine last year when they were shipped via DHL.
    Mike
    SDA SRS 2.3TL's
    SDA 2B TL's
