wireless router- help
TroyD
I've got a Belkin Wireless G router from my laptop here in Shangri-La.
Lately, this thing will go offline and a the only thing to get it back online is a series of restarting it and the computer.....it's pretty aggravating, really.
Any ideas or is this sort of shiite normal??
BDT
BDT
Post edited by TroyD on
where are you...back in Iraq? Probably near a uranium stash that's putting out radiation interference.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
Nah, I'm in lovely Republic of Korea...I plan for the future. - F1Nut
Is it one of those little grey square Belkins? Those are kinda notorious for dying in a similar way to what you describe.If you will it, dude, it is no dream.
Make sure you have the latest firmware update on it also......Testing
Testing
Testing -
Whats funny about routers is that most of them do this. It's like it has a internal clock that gets set at random and then it decides it's time to mess with you.
I got rid of that problem when I got a Apple Airport Extreme. If you have the ability to ge one there, do yourself a favor. They cost alittle more then your average router but it's not your average router. Not to mention it's a N router 10/100/1000.
If not the firmware upgrade of yours is a good place to start.
DanDan
Belkins have a history of doing this, also they like to just crap out all of a sudden. When you restart the router that reactivates the wireless and after a while of use it gets tired and shuts off. If I were you I would order yourself a linksys router.HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
bigaudiofanatic wrote: »Belkins have a history of doing this, also they like to just crap out all of a sudden. When you restart the router that reactivates the wireless and after a while of use it gets tired and shuts off. If I were you I would order yourself a linksys router.
Or a Netgear. I never needed to restart mine except on VERY hot days (without A/C in the house); that's most likely due to the NAT chip getting hot or something like that, not really a fault of the router.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
+1 on the linksys. I never had any issues with mine. Check to see if there are any updates for it Troy if not I would consider replacing it.
Actually not all the Belkins, I have a Pre-n (Version 2) that I never have to restart. Its on a tower thats on 24/7 that uploads weather data.Testing
Testing
Testing -
Every router I've gone through does this occasionally. I got fed up and purchased a business grade Netgear router. Sure it was a little more expensive (around $200-$300 I believe) but it has worked flawlessly. I've never had an issue with it.
It's a bit more money but I always suggest going the business grade route if you can. Much more reliable. -
I get about 2 years out of one, before I need to replace it residential version. So ~$25 a year, to help with the life of the unit I place it by itself as I feel heat is an issue with it's life span.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Stick with Linksys. I have BEFSR41 wired router, bought in 1999, and a WRT54G bought in 2001. Both are still working fine, and have had to be restarted maybe 3 times since new.
Troy, a firmware upgrade may solve the problem. Call the tech help line or go to their website.
Spend $30 of your per diem on a Linksys, done.
Fhead.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
Stupid question Troy but did you reset the router? There is usually a little button on the back od the router that you can push in with a pencil, this clears the cache, and resets the router to stock. I have to do this with my Linksys about every 12-18 months.
Do you use the "Repair Connection" feature of Windows before doing those other things?
As for Belkin....yep.
What are you doing in Korea? My pops is in special ops over there right now. Maybe you would know him?Denon X7200WA
LSiM 705 703 704c
Denon DP 400
Yamaha CDC 775 -
I would update the firmware, and here's the troubleshooting from Belkin. Hope it helps.
Paul
Symptom
Not able to connect to the router/AP wirelessly, or intermittent wireless connection.
Resolution
To address this issue, follow the steps below:
Note : The steps below are applicable only for Belkin routers.
Open an Internet Explorer window on your computer and type in http://192.168.2.1 in the address bar. This will take you to the Belkin router's web based configuration page. If you are not able to open the page click here.
You will get a login page. Leave the password blank. Click Submit .
On the left side of the page, click Channel and SSID below Wireless .
The wireless channel on the Belkin router is set to Auto by defualt. Change the wireless to a static channel. Click Apply Changes .
Click Logout in the top right hand corner.
Note: The wireless card in the computer will automatically detect the change in channel number on the router and will update the channel on the card.
Cause
You are not able to connect wirelessly mainly due to environmental interference. When the wireless channel is set to auto, the router will cycle to though channels when it detects significant interference. When the router changes channel the wireless connection will reset itself and disconnect all wireless clients connected to the router.
Summary
Wireless signals are prone to interference from cordless phones and electrical appliances (e.g., vacuum cleaners, microwave ovens). This is the reason wireless connections can drop. This article explains how to overcome frequent wireless disconnections by changing the channel number (frequency) on the Belkin router.Onkyo 805
(3) Outlaw Audio 2200 Monoblocks
Fronts: Polk RTi10's
Center Polk CSi5
Surrounds Polk FXi3's
Rears Polk FXi30's
Sub Polk PSW125 -
Troy
No problem
Most of the time, it's just a setting. I do this junk for a living, so I run into it all the time.Onkyo 805
Center Polk CSi5
Rears Polk FXi30's
Sub Polk PSW125 -
