wireless router- help
edited August 2008 in The Clubhouse
I've got a Belkin Wireless G router from my laptop here in Shangri-La.
Lately, this thing will go offline and a the only thing to get it back online is a series of restarting it and the computer.....it's pretty aggravating, really.
Any ideas or is this sort of shiite normal??
BDT
Post edited by TroyD on
Welcome!
    edited August 2008
    where are you...back in Iraq? Probably near a uranium stash that's putting out radiation interference.
    edited August 2008
    Nah, I'm in lovely Republic of Korea...
    edited August 2008
    Is it one of those little grey square Belkins? Those are kinda notorious for dying in a similar way to what you describe.
    edited August 2008
    Yes, little square Belkin....
    edited August 2008
    Make sure you have the latest firmware update on it also......
    Testing
    Testing
    Testing
    edited August 2008
    Whats funny about routers is that most of them do this. It's like it has a internal clock that gets set at random and then it decides it's time to mess with you.
    I got rid of that problem when I got a Apple Airport Extreme. If you have the ability to ge one there, do yourself a favor. They cost alittle more then your average router but it's not your average router. Not to mention it's a N router 10/100/1000.
    If not the firmware upgrade of yours is a good place to start.
    Dan
    Dan
    edited August 2008
    Belkins have a history of doing this, also they like to just crap out all of a sudden. When you restart the router that reactivates the wireless and after a while of use it gets tired and shuts off. If I were you I would order yourself a linksys router.
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
    edited August 2008
    Or a Netgear. I never needed to restart mine except on VERY hot days (without A/C in the house); that's most likely due to the NAT chip getting hot or something like that, not really a fault of the router.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
    edited August 2008
    +1 on the linksys. I never had any issues with mine. Check to see if there are any updates for it Troy if not I would consider replacing it.
    edited August 2008
    Actually not all the Belkins, I have a Pre-n (Version 2) that I never have to restart. Its on a tower thats on 24/7 that uploads weather data.
    Testing
    Testing
    Testing
    edited August 2008
    Every router I've gone through does this occasionally. I got fed up and purchased a business grade Netgear router. Sure it was a little more expensive (around $200-$300 I believe) but it has worked flawlessly. I've never had an issue with it.
    It's a bit more money but I always suggest going the business grade route if you can. Much more reliable.
    edited August 2008
    I get about 2 years out of one, before I need to replace it residential version. So ~$25 a year, to help with the life of the unit I place it by itself as I feel heat is an issue with it's life span.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
    edited August 2008
    Stick with Linksys. I have BEFSR41 wired router, bought in 1999, and a WRT54G bought in 2001. Both are still working fine, and have had to be restarted maybe 3 times since new.
    edited August 2008
    Troy, a firmware upgrade may solve the problem. Call the tech help line or go to their website.
    edited August 2008
    Spend $30 of your per diem on a Linksys, done.
    Fhead.
    edited August 2008
    Stupid question Troy but did you reset the router? There is usually a little button on the back od the router that you can push in with a pencil, this clears the cache, and resets the router to stock. I have to do this with my Linksys about every 12-18 months.
    Sean
    XboxLive--->avelanchefan
    PSN---->Floppa
    http://card.mygamercard.net/avelanchefan.png
    edited August 2008
    Do you use the "Repair Connection" feature of Windows before doing those other things?
    As for Belkin....yep.
    What are you doing in Korea? My pops is in special ops over there right now. Maybe you would know him?
    Denon X7200WA
    LSiM 705 703 704c
    Denon DP 400
    Yamaha CDC 775
    edited August 2008
    I would update the firmware, and here's the troubleshooting from Belkin. Hope it helps.
    Paul
    Symptom
    Not able to connect to the router/AP wirelessly, or intermittent wireless connection.
    Resolution
    To address this issue, follow the steps below:
    Note : The steps below are applicable only for Belkin routers.
    Open an Internet Explorer window on your computer and type in http://192.168.2.1 in the address bar. This will take you to the Belkin router's web based configuration page. If you are not able to open the page click here.
    You will get a login page. Leave the password blank. Click Submit .
    On the left side of the page, click Channel and SSID below Wireless .
    The wireless channel on the Belkin router is set to Auto by defualt. Change the wireless to a static channel. Click Apply Changes .
    Click Logout in the top right hand corner.
    Note: The wireless card in the computer will automatically detect the change in channel number on the router and will update the channel on the card.
    Cause
    You are not able to connect wirelessly mainly due to environmental interference. When the wireless channel is set to auto, the router will cycle to though channels when it detects significant interference. When the router changes channel the wireless connection will reset itself and disconnect all wireless clients connected to the router.
    Summary
    Wireless signals are prone to interference from cordless phones and electrical appliances (e.g., vacuum cleaners, microwave ovens). This is the reason wireless connections can drop. This article explains how to overcome frequent wireless disconnections by changing the channel number (frequency) on the Belkin router.
    Onkyo 805
    (3) Outlaw Audio 2200 Monoblocks
    Fronts: Polk RTi10's
    Center Polk CSi5
    Surrounds Polk FXi3's
    Rears Polk FXi30's
    Sub Polk PSW125
    edited August 2008
    COOL, thanks!
    edited August 2008
    Troy
    No problem
    Most of the time, it's just a setting. I do this junk for a living, so I run into it all the time.
    Onkyo 805
    Center Polk CSi5
    Rears Polk FXi30's
    Sub Polk PSW125
    edited August 2008
    hmmmm, guess I must be on ignore......
    Testing
    Testing
    Testing
Welcome!
Welcome!
