LSi9's - Do they go ALL the way? (not ****)
OK - Barely setup but already having serious LSi pangs. Can't afford full set but... considering runing a pair of LSi9's off Speaker's B from my Parasound Amp. (Speakers 'A' would be disabled)
So here's the question: Can SAFELY run the 9's without sub (obviously would have to be set as large)
The spec's would NOT seem to indicate this as ideal,(Overall Frequency Response 38Hz - 27kHz
Lower -3dB Limit 50Hz)
but many folks have said they do this.
LR Setup:
Polk RTi10's, RTi6's, CSiA6 (5 ch setup)
Onkyo 705 & Denon 3808ci Receiver, Onk 875
Parasound 2250 Amp
Sony 26" KDL series Bravia LCD
Panny DMR-EH75 Recorder
Panny DVD-F87 (5 disk DVD player)
NAD T585 (DVD/SACD)
Yamaha DVD-C961 (5 disk SACD/DVD)
SciAnt Explorer 8500HD Cable Box
Orig & 5Gen iPods, , Wii
Plans/Fantasies:
400 disk player that handles ALL formats, sounds as good as NAD with Panasonic interface & compatability.
Parasound 2250 Amp
NAD T585 (DVD/SACD)
Plans/Fantasies:
Post edited by xandra on
Yes, but bass response will vary upon the room and placement."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Music should be pretty good. You will probably want to add a sealed sub later if music is your main goal;)Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
if you are going to use it for HT, be careful - there is only so much Xmax those 2 5.25" will travel...my 7.(1x4) HT setup
TV - Mitsubishi WD-65734
AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
Front - Emerald Physics CS2
Center - JTR Triple 12LF
Surround L/R / Back - Polk RTi4 / Polk FXi A4
Sub - 4 X Hsu ULS15 playing nearfield
DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
Belkin PURE AV PF60 / UPS
Buttkicker
http://www.polkaudio.com/forums/showthread.php?t=60612 -
You'll be fine. Go for it. Add a sub later if/when funds allow.
Until then, you should still get great performance for movies and music.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
Probably should explain: I'd be using the LSi9's exclusively for music (mostly classical).
Reason for my concern: I've been told that it's bad to send out of range frequencies to speakers, since it can damage the coils.
I generally listen at quiet levels and never jack up the bass. BUT orchestral music often contains sudden large bursts of sound - frequently in lower registers.
Ben: what's a "sealed sub"?
PS: connected your cables to my SACD player last nite, (after a week of training in my BR) they sound gawgeous.LR Setup:
Parasound 2250 Amp
NAD T585 (DVD/SACD)
Plans/Fantasies:
400 disk player that handles ALL formats, sounds as good as NAD with Panasonic interface & compatability. -
A sealed sub is exactly what it implies. A sealed enclosure. AKA: No port.
Just a cube and a woofer.Living Room Rig:D
Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
Xbox360/PS3/WII
M.Br. setup:)
Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
Computer Rig:
Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
