LSi9's - Do they go ALL the way? (not ****)
xandra
xandra Posts: 291
edited August 2008 in Speakers
OK - Barely setup but already having serious LSi pangs. Can't afford full set but... considering runing a pair of LSi9's off Speaker's B from my Parasound Amp. (Speakers 'A' would be disabled)
So here's the question: Can SAFELY run the 9's without sub (obviously would have to be set as large)
The spec's would NOT seem to indicate this as ideal,(Overall Frequency Response 38Hz - 27kHz
Lower -3dB Limit 50Hz)
but many folks have said they do this.
LR Setup:
Polk RTi10's, RTi6's, CSiA6 (5 ch setup)
Onkyo 705 & Denon 3808ci Receiver, Onk 875
Parasound 2250 Amp
Sony 26" KDL series Bravia LCD
Panny DMR-EH75 Recorder
Panny DVD-F87 (5 disk DVD player)
NAD T585 (DVD/SACD)
Yamaha DVD-C961 (5 disk SACD/DVD)
SciAnt Explorer 8500HD Cable Box
Orig & 5Gen iPods, , Wii
Plans/Fantasies:
• 400 disk player that handles ALL formats, sounds as good as NAD with Panasonic interface & compatability.
Post edited by xandra on
  • Face
    Face Posts: 14,340
    edited August 2008
    Yes, but bass response will vary upon the room and placement.
  • ben62670
    ben62670 Posts: 15,969
    edited August 2008
    Music should be pretty good. You will probably want to add a sealed sub later if music is your main goal;)
    Ben
  • SlowcarIX
    SlowcarIX Posts: 887
    edited August 2008
    if you are going to use it for HT, be careful - there is only so much Xmax those 2 5.25" will travel...
    my 7.(1x4) HT setup
    TV - Mitsubishi WD-65734
    AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
    Front - Emerald Physics CS2
    Center - JTR Triple 12LF
    Surround L/R / Back - Polk RTi4 / Polk FXi A4
    Sub - 4 X Hsu ULS15 playing nearfield
    DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
    Belkin PURE AV PF60 / UPS
    Buttkicker
    http://www.polkaudio.com/forums/showthread.php?t=60612
  • AndyGwis
    AndyGwis Posts: 3,655
    edited August 2008
    You'll be fine. Go for it. Add a sub later if/when funds allow.
    Until then, you should still get great performance for movies and music.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • xandra
    xandra Posts: 291
    edited August 2008
    Probably should explain: I'd be using the LSi9's exclusively for music (mostly classical).
    Reason for my concern: I've been told that it's bad to send out of range frequencies to speakers, since it can damage the coils.
    I generally listen at quiet levels and never jack up the bass. BUT orchestral music often contains sudden large bursts of sound - frequently in lower registers.
    Ben: what's a "sealed sub"?
    PS: connected your cables to my SACD player last nite, (after a week of training in my BR) they sound gawgeous.
    LR Setup:
    Parasound 2250 Amp
    NAD T585 (DVD/SACD)
    Plans/Fantasies:
  • TouchOfEvil
    TouchOfEvil Posts: 967
    edited August 2008
    A sealed sub is exactly what it implies. A sealed enclosure. AKA: No port.
    Just a cube and a woofer.
    Living Room Rig:D
    Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
    Xbox360/PS3/WII
    M.Br. setup:)
    Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
    Computer Rig:
    Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
    Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
