tweeter problems
jjcool141
jjcool141 Posts: 9
edited August 2008 in Car Audio & Electronics
so im starting to have problems with my SR6500s.
The left tweeter is starting to go scratchy. if i put it louder it tends to clear up but at relativly low volumes it sounds pretty bad.
is there a way i can get a replacement tweeter?? If not i was thinking about getting a seperate set of tweeters, how would this work with the polk woofers???
any help would be appreciated!
thanks
J
Post edited by jjcool141 on
  • exalted512
    exalted512 Posts: 10,734
    edited August 2008
    You can call Polk and get one tweeter sent to you. I believe its about 60 bucks.
    -Cody
  • jjcool141
    jjcool141 Posts: 9
    edited August 2008
    ive heard that you should get tweeters that are as close together as possible. in other words a tweeter build today will be slightly different than 4 weeks from now.
    should i get a set of tweeters rather than just one replacement?
  • exalted512
    edited August 2008
    sounds like a load of bs to me. id just buy one.
    -Cody
  • MacLeod
    MacLeod Posts: 14,358
    edited August 2008
    Scratchy? You sure its the tweeter going screwy and not something else making a noise that you cant hear over the louder volume? I had a judge get out of my car and tell me my right tweeter was crackling. I got in and listened and it was my door panel vibrating up high near and it sounded like it was coming from the tweeter.
