Need a pre,dac,???suggestions please.
TouchOfEvil
TouchOfEvil Posts: 967
edited August 2008 in Electronics
Ok so i bought two amps. The stuff in the living room is fine for me not really wanting to add a pre or a dac to it, i thinmk the Rotel-RB976 will be good enough?
I may get another two channel amp a little later for it then run the fronts on one amp and the center/surrounds on the amp i just bought. Would this be a good idea for later? Run the center/backs on the rotel and the fronts on another amp? If so any decent two channel amps for around 350 or less?
On the bedroom stuff though i was looking at emotiva MMC-1 but the site says it's out of stock. I guess i can give em a call and see about getting one from them.
I am goin to run a Rotel RMB-1075 from dorokusai. I figure this should get me by until i upgrade to bigger better fronts.
But do i need a dac for this setup? If so what units should i look at?
Also would it be better to play cd's on a dvd player? or should i get a cdplayer specific for it?
If so what units are nice?
Right now i am just playing cd's with a cheap sony dvd player cause it's 5 disc so it makes life easier than using the toshiba hddvd player.
Also any good eq's i should look into or is this not really needed?
So any suggestions on what i should be looking at next etc?
Thanks!!!
Living Room Rig:D
Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
Xbox360/PS3/WII
M.Br. setup:)
Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
Computer Rig:
Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
Post edited by TouchOfEvil on
  • joeparaski
    joeparaski Posts: 1,865
    edited August 2008
    Call Emotiva just in case. I got a B-stock MMC-1 at a good price.
    Joe
    Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
    treitz3 Posts: 20,119
    edited August 2008
    I would advise staying away from the EQ. Not that they aren't fun to play with sometimes, it's just that they knock you off reference and unless you are well versed with gear and audio they tend to act as a crutch for issues IMO. YMMV.
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited August 2008
    That Emotiva gear is nice, I'd definitely give them a call, or see if you could find it on the used market
  • TouchOfEvil
    edited August 2008
    I've been looking but had very little luck finding stuff from emotiva used. Have not called yet but i'm sure i will by monday.
    Living Room Rig:D
    Xbox360/PS3/WII
    M.Br. setup:)
    Computer Rig:
  • Shicks18
    Shicks18 Posts: 397
    edited August 2008
    touch - I would upgrade your Pre, CD Player, Subwoofer, Interconnect cables, DAC. In that order. You will see the most improvement for the money in that order is why.
    TV: LG 55LW5600
    Pre: Marantz SR6001
    Front Amp: Parasound HCA-1000A
    Center Amp: Marantz MA500
    Mains: Polk LSi9
    Center: Polk LSiC
    Sub: HSU VTF-3 MK-2
    Games: Xbox360 and PS3
  • TouchOfEvil
    edited August 2008
    Why do i need to upgrade my subwoofer?
    Also what cd players should i look into?
    Living Room Rig:D
    Xbox360/PS3/WII
    M.Br. setup:)
    Computer Rig:
  • fbm211
    fbm211 Posts: 1,488
    edited August 2008
    CDP-Rotel 1072 OR a seperate transport/DAC.--Used ones from the FM or audiogoN.Or ebay of course.Do some reserch on the unit before you buy it too.
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • TouchOfEvil
    edited August 2008
    fbm211 wrote: »
    I was actually reading reviews on that unit earlier today. Seems like a nice piece but i'm wondering if any of their DVD players can compare to it in sound quailty etc? Or should i just roll the cd player for cds and a dvd player for dvds?
    Living Room Rig:D
    Xbox360/PS3/WII
    M.Br. setup:)
    Computer Rig:
  • fbm211
    fbm211 Posts: 1,488
    edited August 2008
    I would go with dedicated CDP and a seperate DVD player.Like a toshiba HD-A1 that you can get real cheap on ebay.Ive seen them go as low as 40.00.
  • candyliquor35m
    candyliquor35m Posts: 2,267
    edited August 2008
    I may have a audio experience symphonies tube pre- for sale fairly soon.
