Receiver Power Ratings
Dr. Spec
http://www.geocities.com/Area51/Hollow/3401/ratevsac.htm
Finally found this link in another forum, and I'm bookmarking it at home. It is updated occasionally, and it really addresses the "all channels driven simultaneously" issue with respect to rated power vs. actual delivered power.
Just an FYI.
Doc
Just an FYI.
Doc
SVS
SVS
Post edited by Dr. Spec on
I'd say the Doc. must have quite the influence, seems to have overloaded the site...
Yahoo!
Sorry, this site is temporarily unavailable!
The web site you are trying to access has exceeded its allocated data transfer. Visit our help area for more information.
Access to this site will be restored within an hour. Please try again later.
http://www.geocities.com/Area51/Hollow/3401/ratevsac.htm -
seems like its back up now. Very interesting stuff indeed. Check out the ratings for the Marantz SR-7200... Yikes.
I didn't get to read it,it's down.....that sucked....Well you will be suprised whats outputing compared to spec's............remember what I said along time ago about that??????Dan
Cool stuff..love that Rotel. Hey man thanks for that link.suds, suds and more suds!
down again, everytime i check it's down...TWFTPQ
Receiver: Outlaw 1050
Amps: Outlaw M-200 x 3 (Powering Mains and Center)
Mains: RT800i; Center: CS400i; Surrounds: F/X500i
Sub1: 214L Vented Tempest
Sub2: 122L Sealed Tempest -
For those who cant access the site, the data is in the attached excel sheet-izafar
Goldenear Technology Triton 1 - Benchmark AHB2 - Benchmark LA4 - Auralic Vega - Auralic Aries Mini - Marantz TT-15S1 - Clearaudio Nano -
How many people actually have problems clipping thier receivers?
My point being, while it's neat 'gee-whiz' type info (I'm not bashing it)....in the end, I feel it's rather meaningless.
Yeah, it's nice to know if what you bought performs like you expecet it too...I know mine does....
Plus it makes you wonder about some of the units they testest...were they defects....like the marantz 7200 and the interga...ouch!
I think it is good information to know, but not base a purchase off of. But it certainly can help sway a decision. I almost bought the marantz 7200...but when i auditioned it, it sounded loud, but not powerful if that makes sense to anyone...*sigh*...good thing I went with my gut on that one...heh
-BL
-BLTWFTPQ
Couple of notes here, from the info that I've gathered, output testing is not an exact science in that I'm willing to bet that if you take five different measurements you could very easily come up with five different readings. Much like measuring the rated HP of an engine. I could be wrong on this however.
What I was really driving at is, as long as you have sufficient power to drive your speakers, which I'm going to assume that most do as I can't think of too many people complaining that they are having problems with clipping, what's the difference?
Third, if I remember correctly (and I probably am not) in order to get a 3db increase in volume you have to double the power (or something along those lines)...anyway, the point is this, the difference that 5 or 10 watts make is so minute as to be virtually indistinguishable.
Now, having said that, I'm all about being skeptical about the claims of a manufacturer even the ones carried by the benevolent philanthropists at Tweeter. However, in the grand scheme, I don't think that these measurements are all that telling.
BDT
Troy,
Your memory is just fine... want 3 more db, double the power.
Interesting thing to me that was within a line by the same manf, some models exceed spec's while others fall woefully short. Wonder if this is result of a design issue or variation in the production?More later,
Tour...
Vox Copuli
Always on your mind there Troy...............Dan
I can see both sides.
I'm sure if these AVRs were all tested per FTC, that each channel alone would make rated specs. And I doubt there is ever a time when an AVR needs to make full power into all channels at once under music/HT conditions.
With that said, an AVR that comes close to (or meets/exceeds) its rated power with all channels being driven at once is a good indication it is robustly built with high quality components. This in turn gives a potential buyer a warm fuzzy that the rest of the AVR is probably also well built.
Doc"What we do in life echoes in eternity"
SVS -
Sounds right to me. My personal experience has been the Integra was very low on power compared to advertised power. With LSi speakers, my Integra clipped around 94db level, which is not very loud. After adding a Rotel 1075 power amp, the difference was and still is, well, incredible! When I bought the Integra, I was told they were state of the art for that price range...ya, right! The 100W advertised rating was according to the SVS article triple the actual rating.
Rick
