RG6 Quad shield for IC's?
Lowell_M
Lowell_M Posts: 1,660
edited August 2008 in 2 Channel Audio
Has anybody used RG6 Quad Shield for IC's? I've got more RCA compression connectors and RG6 at my disposal than I could shake a stick at and thought maybe I'd try this, but... If somebody has tried this in comparison to say... blue Jeans or Signal Cable, etc... I'd be interested in opinions before going through the effort.
:cool:
HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Cable Analog II IC's
Signal Ultra Bi-Wire Speaker Cables
Post edited by Lowell_M on
  • Shannon W.
    Shannon W. Posts: 568
    edited August 2008
    I may be talking out of turn. But I would think as long as the ohm rating is the same then it should work. But I'm no Rocket scientist. Try it out and do a comparison. what do you have to loose. but be sure you let us know how it works out. I would only do like two first that way you don't waste the connectors.
    Shannon
    50" Samsung Plasma
    Sony STR-DA4ES "use as Pre/amp"
    Pioneer Elite DV-45A DVD Player
    DLO HomeDock Deluxe iPod docking station
    Directv HR20 Sat. Receiver in black
    Sunfire Cinema Grand 7 Signature Amp
    Monster Cable AVS2000
    Monster Cable HTPS 5100 MKII
    Polk LSi 9's Front R/L
    Polk LSiC Center
    Polk LSiFX R/L Surround
    Polk LSi 7's Rear R/L
    SVS PB12-Plus/2
    Velodyne SMS-1
    Sony PS3
    Click Here To View my Rig
    SCompRacer Posts: 9,121
    edited August 2008
    Hi Aaron. I am using Sanders Sound Systems IC's. He uses a small coax, and they work very well. They replaced my Harmonic Technology Pro Silway MK III +. I am not sure about the quad shielded RG6. You could always ask Roger. He has answered every question I ever put to him. Use the email on the contact page. http://www.sanderssoundsystems.com/contact-us.htm You guys get down this way we can do an AB.
    He did tell me he had to travel as his daughter was getting married, so he may not be around for a week or so.
    edited August 2008
    Aaron, I was thinking on the ride home form work, which of late is both unusual and scary. Roger uses a Belden RG59 coax for his IC’s which has a stranded center conductor. This makes them very easy to route and handle. IIRC they do not have a foil shield. They just have a high-value dielectric separating the inner and outer wires so they have a very low capacitance.
    With your quad shielding, and the fact that the audio signal isn’t real high voltage, I wouldn’t think you would have any problems using them for IC’s. They most likely have the solid core, so they will be stiff to handle. You may or may not like the results. I like the coax IC’s and even have Roger's coax speaker cables on my panels, but I have ESL’s which are strange anyway.
  • gidrah
    gidrah Posts: 3,049
    edited August 2008
    I am most confident that if you make ICs to fit your set-up (length, etc), with your given materials, that the IC's will not be the weakest link.
    Make it Funky! :)
