RG6 Quad shield for IC's?
Lowell_M
Has anybody used RG6 Quad Shield for IC's? I've got more RCA compression connectors and RG6 at my disposal than I could shake a stick at and thought maybe I'd try this, but... If somebody has tried this in comparison to say... blue Jeans or Signal Cable, etc... I'd be interested in opinions before going through the effort.
:cool:
:cool:
HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Cable Analog II IC's
Signal Ultra Bi-Wire Speaker Cables
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Post edited by Lowell_M on
I may be talking out of turn. But I would think as long as the ohm rating is the same then it should work. But I'm no Rocket scientist. Try it out and do a comparison. what do you have to loose. but be sure you let us know how it works out. I would only do like two first that way you don't waste the connectors.
Shannon50" Samsung Plasma
Sony STR-DA4ES "use as Pre/amp"
Pioneer Elite DV-45A DVD Player
DLO HomeDock Deluxe iPod docking station
Directv HR20 Sat. Receiver in black
Sunfire Cinema Grand 7 Signature Amp
Monster Cable AVS2000
Monster Cable HTPS 5100 MKII
Polk LSi 9's Front R/L
Polk LSiC Center
Polk LSiFX R/L Surround
Polk LSi 7's Rear R/L
SVS PB12-Plus/2
Velodyne SMS-1
Sony PS3
Click Here To View my Rig -
Hi Aaron. I am using Sanders Sound Systems IC's. He uses a small coax, and they work very well. They replaced my Harmonic Technology Pro Silway MK III +. I am not sure about the quad shielded RG6. You could always ask Roger. He has answered every question I ever put to him. Use the email on the contact page. http://www.sanderssoundsystems.com/contact-us.htm You guys get down this way we can do an AB.
He did tell me he had to travel as his daughter was getting married, so he may not be around for a week or so.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Aaron, I was thinking on the ride home form work, which of late is both unusual and scary. Roger uses a Belden RG59 coax for his ICs which has a stranded center conductor. This makes them very easy to route and handle. IIRC they do not have a foil shield. They just have a high-value dielectric separating the inner and outer wires so they have a very low capacitance.
With your quad shielding, and the fact that the audio signal isnt real high voltage, I wouldnt think you would have any problems using them for ICs. They most likely have the solid core, so they will be stiff to handle. You may or may not like the results. I like the coax ICs and even have Roger's coax speaker cables on my panels, but I have ESLs which are strange anyway.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
I am most confident that if you make ICs to fit your set-up (length, etc), with your given materials, that the IC's will not be the weakest link.Make it Funky!
