Amp recommendations for Monitor 70s + CS2
BjornB17
Hey guys,
I'm thinking about buying a new amplifier to power the front 3 channels of my audio system. The reason I'll be doing this is because i'll be powering 5 surrounds off of the receiver and i doubt that the HK receiver will be able to give ample volume to all 8 speakers in a 19x18 living room (which opens up to the rest of the house ) without clipping or destroying the tweeters.
I have 2x Monitor 70s and a CS2. I would like to bi-amp all 3 of them (with exception of CS2 since it only has a single pair of audio inputs). I'd like to get a 6-channel amp so i can bi-amp all front 3 channels including the center if i ever upgrade to something that has dual inputs.
I'm on a bit over a budget so I'd like to stay under $600 or so if possible, but I'm open to all options. I'll be using pre-outs from a HK receiver to the amp.
Thanks in advance!
Thanks in advance!
KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780
Post edited by BjornB17 on
I don't think the HK 130 has pre-outs.I never had it like this where I grew up. But I send my kids here because the fact is you go to one of the best schools in the country: Rushmore. Now, for some of you it doesn't matter. You were born rich and you're going to stay rich. But here's my advice to the rest of you: Take dead aim on the rich boys. Get them in the crosshairs and take them down. Just remember, they can buy anything but they can't buy backbone. Don't let them forget it. Thank you.Herman Blume - Rushmore
i would be using it with an HK AVR-240 or similar receiver with pre-outsKEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780
i did a little research on the Emotiva UPA-7. It looks pretty sweet. would you guys recommend that one?KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780
I ran a pair of 70's with a Rotel 980 with good results. I imagine a 983 would serve you well.I never had it like this where I grew up. But I send my kids here because the fact is you go to one of the best schools in the country: Rushmore. Now, for some of you it doesn't matter. You were born rich and you're going to stay rich. But here's my advice to the rest of you: Take dead aim on the rich boys. Get them in the crosshairs and take them down. Just remember, they can buy anything but they can't buy backbone. Don't let them forget it. Thank you.Herman Blume - Rushmore
mine sound pretty sweet being pushed by my Anthem MCA-5Onkyo TX NR 5008 modified by The Upgrade Company
Oppo BDP 93 modified by The Upgrade Company
Arcam CD37
Monitor Audio Gold GS 60
Revolver Audio Music 5 towers.(surround)
Vandersteen V2W
