Amp recommendations for Monitor 70s + CS2
BjornB17
BjornB17 Posts: 752
edited August 2008 in Electronics
Hey guys,
I'm thinking about buying a new amplifier to power the front 3 channels of my audio system. The reason I'll be doing this is because i'll be powering 5 surrounds off of the receiver and i doubt that the HK receiver will be able to give ample volume to all 8 speakers in a 19x18 living room (which opens up to the rest of the house ) without clipping or destroying the tweeters.
I have 2x Monitor 70s and a CS2. I would like to bi-amp all 3 of them (with exception of CS2 since it only has a single pair of audio inputs). I'd like to get a 6-channel amp so i can bi-amp all front 3 channels including the center if i ever upgrade to something that has dual inputs.
I'm on a bit over a budget so I'd like to stay under $600 or so if possible, but I'm open to all options. I'll be using pre-outs from a HK receiver to the amp.
Thanks in advance!
KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780
Post edited by BjornB17 on
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    edited August 2008
    I don't think the HK 130 has pre-outs.
  • BjornB17
    BjornB17 Posts: 752
    edited August 2008
    i would be using it with an HK AVR-240 or similar receiver with pre-outs
  • BjornB17
    BjornB17 Posts: 752
    edited August 2008
    i did a little research on the Emotiva UPA-7. It looks pretty sweet. would you guys recommend that one?
  • zombie boy 2000
    edited August 2008
    I ran a pair of 70's with a Rotel 980 with good results. I imagine a 983 would serve you well.
  • jayman_1975
    jayman_1975 Posts: 672
    edited August 2008
    mine sound pretty sweet being pushed by my Anthem MCA-5
    Onkyo TX NR 5008 modified by The Upgrade Company
    Oppo BDP 93 modified by The Upgrade Company
    Arcam CD37
    Monitor Audio Gold GS 60
    Revolver Audio Music 5 towers.(surround)
    Vandersteen V2W
