Broken Tophats for RTA-12's
russj684
russj684 Posts: 3
edited August 2008 in Vintage Speakers
Hello,
Just spoke to Polk CS and they have no remaining parts for my RTA-12's - after a couple moving companies have moved my beloved friends around the plastic standoffs for the wire support frame have cracked and broken (badly)
I can super glue them - but I'd really prefer new ones - anybody know where I can get my hands one some?
Thanks!
Post edited by russj684 on
  • zingo
    zingo Posts: 11,258
    edited August 2008
    Would you be able to use any of these grill-guides? They have worked before for people with the regular grills, so they might work for your tophats too.
  • russj684
    russj684 Posts: 3
    edited August 2008
    Thanks, Zingo - but that's not quite what the issue is... On the RTA 12 the tweeter arrays are on top (and outside of) the driver cabinet and Polk built this cool (albeit fragile) frame of plastic standoffs (about 3" high) one in each of 4 corners attached to a piece of MDF. on top of these plastic standoffs is a metal wire "squared ring" that creates a framework to wrap with speaker cloth. In essence a very airy and open "box" that sound can easily pass through. in my case, these standoffs have become brittle and have been destroyed by the movers. I'm hoping to get new ones. Polk CS was no help.
    F1nut Posts: 52,000
    edited August 2008
    You'll have to make or have someone make new pieces for the frame.
  • zingo
    zingo Posts: 11,258
    edited August 2008
    Oh got ya russ. I was thinking of another part that turns out to be no help to you. :p I know you mentioned superglue, but what about pinning them and using a plastic epoxy?
  • russj684
    russj684 Posts: 3
    edited August 2008
    Hmmm..... The epoxy is an interesting idea - worth a shot. Otherwise I'll have to what F1nut says - I'm hoping not, I'm not the worlds best fabricator :-)
  • tx_polkhead
    tx_polkhead Posts: 248
    edited August 2008
    Some guy has parted out a pair of RTA's on ebay, he list and relist the 'parts' maybe he's got the top hats also. good luck.
    Polk Audio RTA 12c's, Monitor 7c, Monitor 5JR+, SDA CRS+
