B&K AVR307 Last Legs?
wallstreet
wallstreet Posts: 1,405
edited August 2008 in Electronics
If you recall, I thought one of my LS 90's blew a driver. Turns out to be the b&k 307 causing the unpleasant sounds. Too late to customer support. Shipping alone's going to cost a fortune. Got to bite the bullet on this one. Can't just drop this one in the trash.
Post edited by wallstreet on
  • brettw22
    brettw22 Posts: 7,623
    edited August 2008
    So the purpose of the thread is to say what..........you're sending in the amp to get fixed or you're going to fix the speakers.........or both? or what?
  • wallstreet
    edited August 2008
    Yea, amps going in. Not much I can do in regards to the LS90 however. I'll poke the Polk folks to see if any old drivers are in the back of the warehouse. Otherwise, I just need to find out what bonding agent they use to glue the driver to the metal backing and I'm back in business.
  • brettw22
    edited August 2008
    At some point I need to send in my 307 as well..........they have the upgrade that you can do to give it all the processing power of the 507 and will fix everything about your amp............I think the upgrade is something like $495.........
  • wallstreet
    edited August 2008
    The price has gone up. It's now $498. ;^)
    Latest update. Packaging up the 307 for upgrade and repair. This will now get me DPL II, DTS ES, and NEO 6. Additionally, a new driver for the LS90 is on the way. All is well in again in freakin hot Texas.
  • JosephH1
    JosephH1 Posts: 17
    edited August 2008
    B&K did an excellent job upgrading my AVR-307. I am very happy with the results and I am sure you will be too. Fortunately I live 25 miles from the facility and could walk it in to them.
