Sound difference between 250v and 400v caps.
McLoki
In researching upgrading my LSiC - it appears I have all 100v caps in the crossover. For the bass circut, I was planning to use solen caps. I was going to use 2 x 130uf caps to replace the existing 260uf and 1 x 18uf to replace the existing 18uf.
My question is, they are both offered in a 250v and 400v capacity for approximately the same price. The 400v is larger, but I was wondering if there are any sonic differences between the two. (250v vs 400v)
Even the 250v is 2.5x the rating of the 100v that is in there, so I should not need it from a wattage perspective. Just wondering if they sound any different. Since they are different sizes, I would not expect them to sound the same, but you never know.
Thanks everyone.
Michael
Thanks everyone.
Michael
Try both:)Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Thanks...
