Entech Numbercruncher 203.2 DAC
Lowell_M
Lowell_M Posts: 1,660
edited August 2008 in For Sale (FS) Classifieds
Been doing a little refining and I'm actually to the point that I have a piece of extra gear! For sale is my Entech Numbercruncher 203.2 DAC Will sell shipped for $75.
For anybody even thinking of giving a standalone DAC a try this is a no brainer for sure. :cool: I originally bought this because I was using an $80 DVD player as my CD player. The difference was jaw dropping. :eek: When running the digital out of the DVD player to the Entech.
I finally stepped up to the Rotel RCD-1072, so a review will be forthcoming, but not until I finish installing the floor in my living room...ugh....
HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Cable Analog II IC's
Signal Ultra Bi-Wire Speaker Cables
Post edited by Lowell_M on
  • Lowell_M
    edited August 2008
    EDIT: The unit is in perfect shape with one exception. The power cord is easy to knock out of the unit. I never had a problem in normal operation, but when swapping around components or cables and such it is easy to pull the power out and not realize it. The unit was like this when I received and and never caused any frustration, but I thought I should let you know.
    thanks, Aaron
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    billbillw Posts: 7,551
    edited August 2008
    a_mattison wrote: »
    thanks, Aaron
    That is actually a minor issue with all of the Entechs. The power cord does not lock in very tight, so it comes out easily. Not really an issue under most circumstances.
    BTW, this is probably the only high quality DAC that can be purchased for under $100. This was designed for Monster/Entech by some of the brains from Audio Alchemy and Spectral. High quality parts used throughout.
    I have one that I used on my computer rig.
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited August 2008
    I think I sold you that DAC. It's a great unit, and it doesn't get any better for $75.
  • Lowell_M
    edited August 2008
    Yes, you did. I couldn't remember who I got it from this morning. It really opened my eyes (ears) and pulled me further from a "bit-is-bits" mentality.
    Here's my initial post after receiving the DAC:
    http://www.polkaudio.com/forums/showthread.php?t=53820&highlight=entech
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  • AsSiMiLaTeD
    edited August 2008
    helluva deal here for $75 folks
  • danger boy
    danger boy Posts: 15,722
    edited August 2008
    I am interested... what kind of digital inputs does it have?
    PolkFest 2012, who's going>?
  • George Grand
    George Grand Posts: 12,258
    edited August 2008
    2nd in the interest line.
    heiney9 Posts: 25,436
    edited August 2008
    Aaron,
    Did we do a shoot-out with the Entech vs. AMC the last time we all had a gear fest? I can't remember. I was impressed with the Entech when I heard it compared to his DVDp.
    I thought I brought my AMC DAC-8 over for a little one on one? :confused:
  • daboyz
    daboyz Posts: 5,207
    edited August 2008
    I believe it was the first hang out down in the rec room. There definitely was a large difference between the Entech and the player he was using. I don't believe we've had the pleasure of meeting your AMC. Aaron's a cool dude so buy with confidence,ya'all.
  • Lowell_M
    edited August 2008
    danger boy wrote: »
    Sorry, busy weekend and I didn't keep up with the forum... The unit has on coax and one optical input with a selector switch on the back.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  • Lowell_M
    edited August 2008
    heiney9 wrote: »
    Aaron,
    Yea... I think they sounded similar, with a little clarity going to the Entech. Doug's Rotel RCD-1072, though, was worlds better in imaging and sound stage, which sent me down the road to another upgrade...
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  • Systems
    Systems Posts: 14,873
    edited August 2008
    Why hasn't anyone bought this? Do I have to step up?
    Chuck
    Testing
    Testing
    Testing
  • concealer404
    concealer404 Posts: 7,440
    edited August 2008
    I have hopefully the dumbest question you all will ever get out of me....
    Using my setup.... (i run my cds through a 300 disc Sony changer with a digi opti out directly to my reciever.) I have no amps, just an Onkyo HT reciever, will i see a noticable gain out of this? Or will this be something that would actually match better with my two-channel bedroom setup?
    edited August 2008
    I don't think you will see much if any improvement unless the Onkyo has a TRUE analog bypass/direct mode. Otherwise, you are just going from digital, to analog (in the Entech), back to digital (in the Onk) and back to analog for the speaker output. This is because most HT receivers do not have a TRUE analog mode. They all end up going thorough A/D converters>DSP>DACs before they get to the amp stage.
  • Lowell_M
    edited August 2008
    It's hard to say. A lot of the differences you will hear depend on the rest of the equipment in your rig. In your HT, you are currently using the DAC that is internal to your AVR. I am reasonably confident that the DAC in the Entech will sound better than the DAC in your Onkyo because I have experienced a similar trial.
    The good news is... It's about the most inexpensive upgrade I've made, and didn't regret it one bit. If you don't like it, somebody here would buy it and you would only be out the shipping cost.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  • Lowell_M
    edited August 2008
    billbillw wrote: »
    I saw a huge difference going through my H/K AVR 635 when I had this unit in my HT and used it for 2-channel. That was my first step in understanding external DACs and the importance of a good front end.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  • concealer404
    edited August 2008
    So what you guys are saying is that yes.... it's better than the DAC built into the Onkyo, but i may not necessarily be able to take advantage of this unit, BECAUSE of the Onkyo.
    Basically i need to research if i can bypass the internal DAC on either of my recievers before i really look into this stuff. Although i am tempted to just grab it for future use now, anyways.
    I'll make my decision tonite, hopefully it's still here tomorrow if i decide to go for it. :)
  • Danny Tse
    Danny Tse Posts: 5,206
    edited August 2008
    Look in the owner's manual, Onkyo includes a diagram which shows that an analog signal will stay analog. There is a "Direct" mode for 2 channel operation on the 503, but your best bet is the multi-channel analog inputs.
  • concealer404
    edited August 2008
    Danny Tse wrote: »
    Still a little lost.... in looking at the specs on the 203.2, it has a digi or a coax input, and one unbalanced analog output.
    I'll look at the manual tonite and see if i can formulate my question better. :o
  • Lowell_M
    edited August 2008
    What Danny is saying is that your receiver has a direct analog signal path if you use the multichannel inputs (this is a good thing)
    The DAC that I am selling has two inputs, one for digital coax, and one for optical (you can use either). This input would come from your CD player. Then, you use the analog outputs from the Entech DAC to run to the multichannel inputs (L and R) on your receiver.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  • concealer404
    edited August 2008
    a_mattison wrote: »
    Ah hah! That makes more sense.... i was thinking about the surround inputs on my reciever. So this would be a BIG yes to upgrade to in 2 channel listening in particular. But also for the reason that i want to take that load off the reciever, i wouldn't want to then use the Dolby Decoder on the reciever to split into surround, because it would "unpurify" it again, yes?
    I'll definitely let you know tomorrow, provided you haven't dumped it by then. I'm hoping that my Pioneer VSX-50 has the same kindof situation going on with it.
    edited August 2008
    Yes, the multichannel inputs would keep things in analog through the entire path.
    However, this would be a true 2.0 setup though, no sub output when listening that way. Only R/L fronts. We are also assuming that you are not already using the multichannel analog inputs on your Onkyo for SACD or something similar.
  • concealer404
    edited August 2008
    billbillw wrote: »
    Gotcha.... Sounds like i need to see if this will work with the Pioneer/vs-25 setup.
    Man, i'm more noob than i thought.... i always wondered what that little black box was in my dad's setup. :D
  • George Grand
    edited August 2008
    I'm all over that thing if Danger Boy dropped out.
  • Danny Tse
    edited August 2008
    The diagram that I am talking about is on page 21 of the owner's manual for the Onkyo 503.
  • danger boy
    edited August 2008
    I dropped out.. i sent a PM to Aaron explaining why I didn't respond sooner.. a 12+ hour day will do that to a person.
    enjoy whomever it goes to.
    AL
  • Systems
    edited August 2008
    George are you buying this? I'm next.
    Chuck
    Testing
    Testing
    Testing
  • George Grand
    edited August 2008
    It's new home is Jersey. Just waiting for an address to send $ to.
    Chuck, check in with the vinyl thread please.
  • Lowell_M
    edited August 2008
    It's all yours.... PM sent.
    Thanks! Aaron
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  • daboyz
    daboyz Posts: 5,207
    edited August 2008
    a_mattison wrote: »
    Damn, If we did demo both then I gotta start laying off the brewskies:eek::D
